-   -   Brake booster itself gone bad, or check valve? (http://www.jeepforum.com/forum/f12/brake-booster-itself-gone-bad-check-valve-1005208/)
Neo1130 04-03-2010 02:11 PM
Curious if one is more prone to failure than the other? I know the check valve is only about $6 with grommets so I can try that first. But the past month, every time I go out to start the Jeep, the brakes are ROCK hard. It's like the vacuum reservoir is leaking all of the vacuum out and causing the problem. This also happens about 2 hours after shutting the Jeep off. Doesn't cause drive-ability issues but I want to get this fixed before it gets bad and causes an accident.
Mark05059 04-03-2010 02:22 PM
personally for $6 I would do the check valve and if its not it then you will have a spare when you put in the new booster.
The time now is 05:04 AM.
