Brake booster Bad? - JeepForum.com
post #1 of 15 Old 08-28-2007, 04:09 AM Thread Starter
Devildog985
Devildog985's Avatar
Brake booster Bad?
How can you tell if a brake booster is bad. I have the 1995 booster in my 1994.
1994 YJ 5" bds Lift with M.O.R.E 5/8 boomerange shackles and BDS stretch, 1" Daystar Bl, SYE/W XJ d/shaft 8.8
YJ Nation - Big Jim Team YJ - The Revolution Begins
Devildog985 is offline
post #2 of 15 Old 08-28-2007, 06:26 AM
EABiker
A bad booster shows itself with a very hard brake pedal; you almost need 2 feet on the pedal to stop. A vacuum leak at the booster will cause this as well.
EABiker is offline
post #3 of 15 Old 08-28-2007, 08:40 AM Thread Starter
Devildog985
Well Its working then. I just installed all new brake line, new porportioning valve and new master, and used brake booster from a 1995 wrangler. I also did the 8.8 with disc brakes. I have bled the lines completely but when you step on the peddle its mussy at first then hardens up. The old system was an anti lock but I removed it all after the 8.8 install. I was wondering maybe I have the lines coming out of the porportioning valve wrong.
post #4 of 15 Old 08-28-2007, 09:47 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
Or you put the calipers on the 8.8 backwards. The nipple should be at the top, not the bottom. If nipple is at the bottom, switch sides with them.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #5 of 15 Old 08-28-2007, 12:58 PM
GrimJeeper91
GrimJeeper91's Avatar
Hey, I did that once...
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #6 of 15 Old 08-28-2007, 01:53 PM
tony673
Did you bench bleed the new master cylinder before you put it on?
tony673 is offline
post #7 of 15 Old 08-28-2007, 02:03 PM
Tomb Raider
Addicted...
How do you think I know it doesn't work
post #8 of 15 Old 08-28-2007, 03:13 PM
jeepin1995
jeepin1995's Avatar
done it too.......
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #9 of 15 Old 08-28-2007, 07:12 PM Thread Starter
Devildog985
Your not pulling my leg are you? I just went out and checked and the nipple for bleeding the brakes is at the bottom.
post #10 of 15 Old 08-28-2007, 07:34 PM
jeepin1995
jeepin1995's Avatar
nope..... he's being serious for a change.....
post #11 of 15 Old 08-29-2007, 04:04 AM Thread Starter
Devildog985
Well, I checked and the bleeder and it is upside down. I dont have the time tonight but thursday evening I will switch them to see if that helps. Thanks All
post #12 of 15 Old 08-29-2007, 10:22 AM
zeus87gn
1987 YJ Wrangler
Are you sure he doesn't need to flip the axle over?
J/K
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #13 of 15 Old 08-29-2007, 11:17 AM Thread Starter
Devildog985
J/K
LOL They way this installs going that would probably be easier
post #14 of 15 Old 08-29-2007, 07:18 PM Thread Starter
Devildog985
OK, I got some free time tonight and guess what. Tomb Raider is DA man. I swithced them then got my not so cheap help (wife) to help me and walla. All is right in the world. Thanks man
post #15 of 15 Old 08-29-2007, 07:21 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
been there and done it too.........damn ford calipers....
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
Replaced Brake Booster - now brake lights stay on Viking TJ Wrangler Technical Forum 4 04-11-2017 06:46 PM
After brake booster install, brake lights are on??? HoustonRenegade YJ Wrangler Technical Forum 6 05-17-2009 07:49 PM
TJ brake booster in my YJ? czjeeper YJ Wrangler Technical Forum 1 01-18-2009 01:02 PM
Brake Booster? camcrazy YJ Wrangler Technical Forum 7 06-25-2007 10:00 PM
Brake Booster ionakana YJ Wrangler Technical Forum 1 09-28-2006 08:08 AM
