Brake bleeding? - JeepForum.com
post #1 of 11 Old 06-06-2013, 06:39 PM Thread Starter
87laredo
1987 YJ Wrangler
Brake bleeding?
Hello,
I have just completed putting on all new brakes on my yj and even after bleeding the system 6 times I can't get a stiff pedal going. What do I need to do?
Thanks,
Jake
87laredo is offline
post #2 of 11 Old 06-06-2013, 06:55 PM
jbolty
jbolty's Avatar
are the bleed screws on the calipers facing up?
jbolty is offline
post #3 of 11 Old 06-06-2013, 07:09 PM
dillonjm
2013 WK
Did you bench bleed the master (if you replaced it)
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #4 of 11 Old 06-06-2013, 07:17 PM Thread Starter
87laredo
1987 YJ Wrangler
Yes and it's the original master however everything else is brand new. New wheel cylinders,drums,hardware,shoes,rotors,calipers, pads, and lines all new. And would it be necessary to bleed the old master, or is there a fluid resivor in the master that could be low?
87laredo is offline
post #5 of 11 Old 06-06-2013, 07:50 PM
Old4X
1990 CJ7
Look again
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #6 of 11 Old 06-06-2013, 08:34 PM Thread Starter
87laredo
1987 YJ Wrangler
I am 110% sure they are up if I could post pics I would
87laredo is offline
post #7 of 11 Old 06-06-2013, 08:41 PM
bigbossd1030
I had an issue with the callipers when I ha them upside down. Went through three litres if fluid bleeding them. If everything is good bleed them again
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #8 of 11 Old 06-06-2013, 08:53 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Originally Posted by 87laredo View Post
Hello,
Thanks,
Jake
Did you manually adjust the rear brake shoes?
Did you bleed the brakes in the following order:
passenger's side rear, drivers side rear, passenger side front, drivers side front?
If you drained the MC it needs to be bench bled again also.
One other reason for soft pedal can be mushy brake hoses
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #9 of 11 Old 06-06-2013, 09:29 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
X2. Excellent info.
Joe Dillard is offline
post #10 of 11 Old 06-06-2013, 10:09 PM
packdog
Add fluid
In post #4 you ask about a reservoir. Yes, you need to put fluid into it while you are bleeding the lines. If you don't then you will end up with air in the master cylinder and have to bleed the master and start all over again with the lines.
packdog is offline
post #11 of 11 Old 06-07-2013, 05:41 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
Agreed! If you failed to add brake fluid WHILE YOU WERE BLEEDING YOUR BRAKES, you weren't bleeding them, you emptied the entire brake system of brake fluid! The MC reservoir should never be allowed to become empty in the brake bleeding process. That introduces air into the brake system.
And no I won't go with you for a test ride on that steep, narrow mountain road near your home when you are done with this brake job!
