brake bleeder valve. need some help. - JeepForum.com
post #1 of 14 Old 05-05-2010, 08:11 PM Thread Starter
rocknjeep
1987 YJ Wrangler
So I had to put in a new master cylinder as my original one took a dump. That in itself turned out to more of a PIA than I had expected with a stuck line fitting. Anyway got it in and dealt with. Bleed 3 of the brakes and got to the final one when I came across a seized up bleeder valve/screw. Any ideas on how to brake this sucker loose? I'm gonna replace them all with new ones ASAP.
rocknjeep is offline
post #2 of 14 Old 05-05-2010, 08:14 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
If you are gonna replace em, vice grips.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 14 Old 05-05-2010, 08:22 PM Thread Starter
rocknjeep
1987 YJ Wrangler
I tried my grips out on it for a bit but it didn't budge. Just rounded it more. Maybe I should hit it with some PB first?
post #4 of 14 Old 05-05-2010, 08:26 PM
Burnerman
Burnerman's Avatar
front or rear? Rear wheel cylinders are less then $20 ea.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #5 of 14 Old 05-05-2010, 08:26 PM
rustywrangler
What one is it, front back???? YES PB it, maybe overnight.
post #6 of 14 Old 05-05-2010, 08:41 PM Thread Starter
rocknjeep
1987 YJ Wrangler
It's in the front.
post #7 of 14 Old 05-05-2010, 08:42 PM
rustywrangler
UGH, on a caliper. I would spray PB and let it sit overnight.
post #8 of 14 Old 05-05-2010, 08:42 PM
Mark05059
straight jawed vise grips.. the rounded ones dont seem to grab as well..
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #9 of 14 Old 05-05-2010, 08:46 PM
Burnerman
Burnerman's Avatar
You could try a small (6") pipe wrench. Just be sure to grab it as close to the caliper as possible. They snap off pretty easy. Soak it in PB for sure. DO NOT heat it.
96 ZJ.
post #10 of 14 Old 05-05-2010, 09:02 PM
dagoober
i just had the same thing happen with my front left caliper. i wrenched on it too hard and it eventually snapped. i ended up trying to use an easy out (NOT RECOMMENDED!) and it broke inside of it. i ended up prying the easy out from the valve and drilling it but i screwed the threads and the hole was too big when i retapped so i just got a new caliper.
you could propably drill it out if youre careful but its a lot easier to buy a 30$ caliper.
________
l l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
dagoober is offline
post #11 of 14 Old 05-05-2010, 09:12 PM
ritjobbie
Nobody suggested heat yet? I've had luck with heat on a stuck bleeder before. I've also snapped them off inside.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #12 of 14 Old 05-05-2010, 09:28 PM
Burnerman
Burnerman's Avatar
I've seen people have bad luck with heat and cook the seals and fluid out of brake parts.
96 ZJ.
post #13 of 14 Old 05-05-2010, 11:29 PM Thread Starter
rocknjeep
1987 YJ Wrangler
thanks a lot guys. and yea it's my front left. im gonna go pick up some straight jawed vice-grips tomorrow and hit it with pb and let it sit a few hours then see how we do. i'll keep you updated.
post #14 of 14 Old 05-06-2010, 06:56 PM Thread Starter
rocknjeep
1987 YJ Wrangler
got that sucker busted off today and put in some new ones. brakes are all good now. thanks for all the help guys.
Snapped Bleeder Valve jerseyrider1119 YJ Wrangler Technical Forum 16 04-26-2009 08:07 PM
Broke Bleeder Valve chupacabrah YJ Wrangler Technical Forum 13 03-30-2007 10:05 AM
broken bleeder valve, now what? Johnny World YJ Wrangler Technical Forum 14 04-26-2006 10:27 PM
Help - sheared my bleeder valve skifast1 TJ Wrangler Technical Forum 3 08-10-2005 12:00 PM
89 bleeder valve Heinbaugh YJ Wrangler Technical Forum 3 03-25-2005 06:55 AM
