Braided stainless fuel lines - JeepForum.com
post #1 of 9 Old 11-09-2013, 08:47 PM Thread Starter
TSEJEEPERS
I am going to a external fuel pump with my RCI fuel cell.
The fitting sizes on the fuel cell are -8AN.
I am a little confused on what fuel line I can use.
Can you use a braided line like this for a fuel injected engine?
http://www.summitracing.com/int/part...0620/overview/
I would also be using the Summit AN fittings with it.
This would be used to supply the fuel to a stock 4.0L engine in my YJ.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #2 of 9 Old 11-09-2013, 10:06 PM
deathtrap
1000 p.s.i. and designed to handle gasoline. Should work if that's what you want to use.
deathtrap is offline
post #3 of 9 Old 11-11-2013, 11:18 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
I've been curious about this. I need to order some fuel line parts to install my Genright cell. Is the -6an hose equivelant to 3/8 that I need to supply my V8?
Randonexplosion is offline
post #4 of 9 Old 11-11-2013, 04:20 PM
beemerkid
Should be just what your looking for. When you put the connectors on, use a cut off wheel to cut the hose and get a CLEAN edge. Then put a dab of oil on the part of the connector that goes in the hose to make it slide on easier. If you care that the fittings dont get scratched, put electrical tape on your wrench first.
beemerkid is offline
post #5 of 9 Old 11-11-2013, 05:33 PM
imstillatwork
Wrap the hose in electrical or painters tape several winds before you use the cutoff wheel too, much cleaner slice through the layers.
imstillatwork is offline
post #6 of 9 Old 11-11-2013, 08:51 PM Thread Starter
TSEJEEPERS
Ok so here is my problem.
As I said I have never used braided stainless line so bear with me.
I am using this external fuel pump.
http://www.oreillyauto.com/site/c/de...&keyword=e2000
As you can see it has two nipples to attach the fuel lines.
How would I attach the line to the fuel pump?
Thinking I would use this end
http://www.summitracing.com/int/part...890b/overview/
With this adapter
http://www.summitracing.com/int/part...0648/overview/
To this Coupler
http://www.summitracing.com/int/part...3erl/overview/
Then I could use a brass nipple
http://www.farmandfleet.com/products...hose-ends.html
and then use rubber fuel injection hose to attach the fuel pump.
Am I over thinking this?
post #7 of 9 Old 11-11-2013, 10:02 PM Thread Starter
TSEJEEPERS
I.D. is listed at 11/32
Is that 3/8 I.D or O.D.?
post #8 of 9 Old 11-11-2013, 10:16 PM
Randonexplosion
Deplorable
ID. I guess I just need to browse Summit a bit more...
post #9 of 9 Old 11-12-2013, 08:13 AM
tom_sprecher
On the race car I had -8 from the cell to the filter and pump and then -6 to the carb and -4 for the return line. It got 6 mpg so I think those sizes can feed your 4.0.
The -AN number is the ID of the hose or fitting in 1/16" increments. A -8 is 8/16" or 1/2" ID. If Summit does not have what you want try Pegasus.
https://www.pegasusautoracing.com/ad...oryID=PLUMBING
I've dicked with enough AN fittings over the years that I have a set of vice jaw blocks just for -AN fittings and they really make assemble easier. Also the best tape to use on the smaller hose (-4 will really want to unravel and splay out as soon as you cut it with the zizz wheel) is the reinforced clear packing tape with the fiber glass strands.
Like this.
Tom
tom_sprecher is offline
