Bouncy ride - JeepForum.com
post #1 of 12 Old 03-28-2013, 07:38 PM Thread Starter
mlelah
Bouncy ride
I had replaced my front stock suspension with new springs and bushings. But I used the red polyurethane bushings. Now the ride is very bouncy. Is this due to the bushings? If I used oem rubber bushings would the ride be smoother? Shocks are nearly new.
mlelah is offline
post #2 of 12 Old 03-28-2013, 07:49 PM
Wrangler11
Wrangler11's Avatar
It's a jeep. There always bouncy.
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #3 of 12 Old 03-28-2013, 07:58 PM Thread Starter
mlelah
but how come some folks have smoother rides?
mlelah is offline
post #4 of 12 Old 03-28-2013, 08:57 PM
jokerchief462
Are the shackles moving when it flexes. They may be too tight. Use nylon lock nuts and cut the torque to 45 ft/ lbs. see what that does and yes when it is on the ground not in the air.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #5 of 12 Old 03-29-2013, 03:31 AM
Chrisnvegas
INFIDEL
Chrisnvegas's Avatar
My Jeep is NOT bouncy.
You never said what kind of springs you got, or shocks for that matter. Did you over-tighten your shackles? Did you pull the track bars and sway bars and throw them on you scrap metal pile?
I have poly bushings and they are not stiff at all.
GET OFF MY LAWN!
Chrisnvegas is offline
post #6 of 12 Old 03-29-2013, 07:32 PM Thread Starter
mlelah
oem springs. Monroe sensor trac shocks. I will loosen the shackle nuts to 35. Is removing the sway bar ok for street riding?
mlelah is offline
post #7 of 12 Old 03-29-2013, 07:51 PM
jokerchief462
Trac bars off but I run my sway bar on the street. Quick disconnects for the trail.
post #8 of 12 Old 04-05-2013, 08:38 PM Thread Starter
mlelah
So I just removed my trac bars (front and rear). Although some improvement (a little less bouncy), I was hoping for more. And there is a little instability with the trac bars off.
Here's where I am:
Daily driver no lift
OEM leafs - about 1 year old
Monroe Sensatrac shocks - about 1 year old
No trac bars
Sway bar connected
Red poly shackle bushings
Shackle bolts 45 ft lb
Eye bolts 65 ft lb
tires 28 lb
What else can I do or check to further improve the ride? Thanks
mlelah is offline
post #9 of 12 Old 04-05-2013, 11:09 PM
ROTTEN
Improve?
Its a leaf sprung short base vehicle. If it doesnt tip over on a tighg turn then it is riding smoothly
If it does flop just push it back over and go..
I'm new
ROTTEN is offline
post #10 of 12 Old 04-06-2013, 12:36 PM
pasinbuy
Here's where I am:
No trac bars
Sway bar connected
Eye bolts 65 ft lb
tires 28 lb
Looks to me that you did it all. You are not driving a Lexus, it is a Jeep Yj.
All vehicles have their own ride and handling characteristics from Pickup, to Lexus, Vett, Camero, to Jeep. Drive what you enjoy.
pasinbuy is offline
post #11 of 12 Old 04-06-2013, 12:43 PM
Sparrows
Maybe I missed it, but how long are your shackles?
Cheers
June '13 YJOTM
Sparrows is offline
post #12 of 12 Old 04-06-2013, 01:53 PM
alexladwig
Originally Posted by ROTTEN
Improve?
Bahahahaha ^^^^ X2
alexladwig is offline
