Bought a yj with shackles, questions... - JeepForum.com
post #1 of 6 Old 04-05-2009, 03:01 PM Thread Starter
yjJeff
I bought a 91 yj with shackles, it has 31" tires on it now, but i have some questions. Is it okay to put a suspension lift on the shackles, or should I get the bigger lift and remove the shackles? I'm planning on putting a 1" body lift on the jeep with the shackles for now, and maybe do a whole suspension when I have the money. What are the problems with shackles, if any? Any advice would be appreciated, thanks.
yjJeff is offline
post #2 of 6 Old 04-05-2009, 03:02 PM
yellowford
A lot of guys run longer shackles with a suspension lift, and also a 1" body lift.
XJ hunting
yellowford is offline
post #3 of 6 Old 04-05-2009, 03:08 PM
Tompatt
1987 YJ Wrangler
how big are the shackles... I run 4" lift with 3/4 shackles.
Thomas
-1987 YJ
Tompatt is offline
post #4 of 6 Old 04-05-2009, 03:16 PM Thread Starter
yjJeff
I dunno. they were on the jeep already. Where do you measure the shackles?
yjJeff is offline
post #5 of 6 Old 04-05-2009, 03:21 PM
longboy
2006 WK
Measure the distance between the bolts on the shackle. Stock YJ shackles are 4" from bolt to bolt. If your shackles are 5", they yeild " of lift over stock.
2006 5.7l WK
longboy is offline
post #6 of 6 Old 04-05-2009, 03:29 PM
Tompatt
1987 YJ Wrangler
like my 2" shackles..
Thomas
-1987 YJ
Tompatt is offline
Questions on how to order MORE Shackles YJames90 YJ Wrangler Technical Forum 5 04-28-2008 07:13 PM
shackles...a few questions Tim3852 YJ Wrangler Technical Forum 6 03-05-2007 09:29 PM
Lift kit install---shackles questions pezley YJ Wrangler Technical Forum 10 03-31-2006 09:41 AM
Few questions about shackles Ryanjeeper YJ Wrangler Technical Forum 5 02-05-2006 10:27 PM
Questions on shackles and winches. yj@vt YJ Wrangler Technical Forum 3 03-19-2002 11:32 AM
