Bought my 3rd Jeep last night - 2.5 liter with major oil leak - JeepForum.com
post #1 of 16 Old 04-15-2010, 06:40 AM Thread Starter
Area.3.Fiftyone
I just picked up yet another Jeep last night (93 YJ for $1200) and there is something leaking pretty bad on the passenger side near the distributor.
I found it on Craigslist and I was the first one there with cash. Georgia Jeep most of it's life with ZERO rust. 2.5 liter, 5 speed, soft top and 137k miles.
The PO says it doesn't leak at idle, but it sprays all over the distributor cap and passenger side of the block while at cruising speed.
I haven't even had a chance to look at it yet, but was wondering if anyone has come across this same problem or if there is a known issue with the 2.5 liter motor that would cause this?
I'm hoping it's just a bad oil filter seal, distributor shaft seal, or something simple to fix. The valve cover gasket has already been changed and it didn't help.
Any thoughts on what else could be causing it to leak so bad on that side of the motor?
Any advice is much appreciated.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #2 of 16 Old 04-15-2010, 06:48 AM
EABiker
The oil pressure sending unit is on that side; it should certainly have the pressure to spray like that if it has a bad seal!
EABiker is online now
post #3 of 16 Old 04-15-2010, 07:12 AM Thread Starter
Area.3.Fiftyone
I'm going to wash the whole engine down with some degreaser and see if I can't pinpoint it.
After doing some searching here, it looks like it could be the sender or the o ring for the oil filter adapter.
I'll let you guys know what I find.
post #4 of 16 Old 04-15-2010, 08:05 AM
bharris68
Daily Driver
x2 on Oil sending unit. I had the exact same problem until I replaced mine. Does the oil pressure gauge register something totally inane?
bharris68 is offline
post #5 of 16 Old 04-15-2010, 09:14 AM
YJake
I have a slight leak on that side of my block as well and am suspecting the oil pressure sending unit. They're cheap plastic sensors prone to breaking. I'll have a look see today and tell you what I find.
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #6 of 16 Old 04-15-2010, 09:16 AM
Colo95YJ
I have also had oil blowing out of the oil dipstick....some days are better/worse than others
Colo95YJ is offline
post #7 of 16 Old 04-15-2010, 09:52 AM
88blkyj
mine also had dipstick leakage...just siliconed it up!
88blkyj is offline
post #8 of 16 Old 04-15-2010, 10:07 AM
Axl Jack
Your 3rd Jeep, eh? Why you gotta be so selfish? Can't let anybody else have any?
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #9 of 16 Old 04-15-2010, 10:08 AM
Colo95YJ
I keep a few wraps of teflon tape on mine
Colo95YJ is offline
post #10 of 16 Old 04-15-2010, 10:41 AM Thread Starter
Area.3.Fiftyone
This isn't the dipstick. It pours/sprays out of something and its ALL over the place on that side.
I just came back with some gas for my power washer and I'm going to blast the whole thing down and take it from there.
post #11 of 16 Old 04-15-2010, 10:44 AM Thread Starter
Area.3.Fiftyone
I was at the salvage yards all day yesterday and I was beat from walking so much in the hot sun.
When I got home, I checked Craigslist while grabbing something to eat as I usually do and saw it was just posted.
I called the guy and he said a bunch of people had called and were on their way over. I was lucky and got there first and bought it on the spot while other people were lining up out on the street!
I still had food in my mouth while I was getting in the truck and I didn't even have time to tie my shoes.....
You have to be quick to get a deal like that. Pics will follow.
post #12 of 16 Old 04-17-2010, 11:00 AM Thread Starter
Area.3.Fiftyone
Update on major oil leak.
Apparently, it is being pushed up out of the dipstick tube. I power washed the entire engine bay the other day and took it for a quick ride around the block today.
You can clearly see that the rubber around the dipstick handle is partially missing and it fits really loose on the tube. It will be no big deal to replace the rubber seal, but the bigger question is going to be: Why is there so much pressure building up in the crankcase?
I checked the orifice on the breather elbow on top of the valve cover and could easily blow through it. The hole looks kind of small (less than 1/8") and I'm wondering if it's just too small to let the crankcase pressure escape? I ran the motor with the elbow disconnected in the driveway and did not see much blow by at all. I did not drive it again with the elbow disconnected though.
Is there something else that I could be overlooking or do to relieve the crankcase pressure?
Thanks in advance for your help.
post #13 of 16 Old 04-17-2010, 12:05 PM
GRYDE001
I have almost the exact same issue....oil leak on the same side. Good to know it might only be the oil sending unit. Sounds like that might be an easy fix if that's the case??
Gonna be washing the engine off tomm and see if that's the case.
GRYDE001 is offline
post #14 of 16 Old 04-17-2010, 12:50 PM
MoparFreak69
I have the same issue. I replaced the oil pressure sender because it wasnt working right anyway, but that didnt fix the problem. It appears my leak is coming from between the head and block, which is strange because the pushrods are on that side of the block. I picked up a head gasket set at autozone for $35 I just havent takent he time to install it. I am working on getting a V-8 setup for my YJ so I dont know if I will screw with it.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #15 of 16 Old 04-17-2010, 01:47 PM
CrushJeep
Oil pump in the pan can push oil up out of the dipstick area. Thats not good. take off the top where you fill it with oil and see if you have any blowby.
CrushJeep is offline
Just bought my New (to me) Jeep last night...Help !!! Texasmusic YJ Wrangler Technical Forum 13 04-27-2010 06:54 PM
Just bought a 2010 Jeep Wranger Rubicon last night!! enderokc JK Wrangler Technical Forum 47 04-27-2010 02:03 PM
just bought a 97 tj w/33" toyos, major vibration 35-50 rugerdog TJ Wrangler Technical Forum 7 07-05-2009 04:49 PM
Driving home last night and I experienced some major issues! Cooneys08JK TJ Wrangler Technical Forum 28 08-02-2008 02:56 AM
Bought my used '95 last night and its got a.... MCTampa YJ Wrangler Technical Forum 4 05-16-2006 07:52 PM
