#1 | |
Both tires spun!!!! Whoo-hoo!
Ok, I've posted on this before, but forgot about it. Today I "popped" the clutch a little while in some wet grass...the passenger rear tire left a 4 foot burn out mark...the driver side rear tire left a 2 foot burn out mark.
This means I have a limited slip diff correct? There are no tags/markings on the rear end so it's hard to tell if the PO messed with it or not...but from what I know if both tires spin (especially if one spins more as evidenced by the longer burn out mark on passenger side) then that indicates LS. I know LS is not all that, but it'd make me feel a little better! <93 YJ, 4.0, 4" Skyjacker lift, 1 1/4" Daystar greasable shackles, 33" BFG A/T, Herc'd interior, Herc'd full doors, trac/sway bar delete, custom primer/gloss black> <80 CJ5, bone stock, fully restored> *SOLD*
#2 |
others can correct me if I am wrong, but I think if you want to know for sure you can always jack up the rear so both tires are off the ground. if you turn one wheel by hand and the other wheel turns in the same direction you have limited slip if the other wheel turns in the opposite direction it is an open diff.
#3 |
MyJKRocks!
All you have told me is that you can spin both tires in wet grass. I can do that with a civic.
Unless the previous owner put in a LS....i'm pretty sure that no YJ came with a LSD. On top of that.....if you are spinning your tires with that stock rear axle, your likely to break it.....just at that point when it gets traction.....POP!!! I've read many posts over the months about ppl doing exactly what you did, "just for fun" or "just that one time." You don't know how many posts are here about busting their stock Dana 35 rear axle because they were doing exactly what you were doing. Food for thought next time you act like Jeff Gordon, when you should be acting like Ivan stewart.
2007 JK Unlimited Sahara 37" Irok ND's 4" rough country lift |
#4 |
Jello Puddin'
YJ's with a stock "Tow Package" came with a rear Posi, at least that's what the guy at the rearend shop told me when he rebuilt mine. (Of course that was before I came here and heard about the 8.8, oh well, just a wasted $1200.)
#5 | |
MyJKRocks!
#6 |
Any open diff will do what you described. If you want to chech for limited slip put one wheel on pavement and one on loose dirt, ice, slick mud, or whatever and lay into the throttle. An open diff will spin the low traction tire like crazy. Limited slip should kick in and move you right along.
With both tires on grass, gravel, etc., the tires can act pretty much equally making some think they have limited slip. Open diff always keep the torque equal at both axle shafts. |
#7 |
i put an open 7.5" behind a 5.0 after i split a 8.8 in 1/2 and i used to spin both almost evrytime..when i had the 7.5 behind my 2.3T it would spin one all the time and never 2..i guess the sudden hit of the 5.0 got em loose
95.5 YJ Rio Grande 2.5L.4" RE,1" BL, 33x9.5 AT's, Aussie Locker -Retired 88 Mustang Notch turbo 2.3 road race car- Street toy 02 Outback Wagon -Daily 00 Yamaha Kodiak on 27"s |
#8 | |
Jello Puddin'
Yeah, Like I said that's what the guy at the shop told me. I personally have NO actuall knowledge of it. I don't know where someone could find an "options list" to see if they even offered a "tow package" or some different rearend LSD or Posi. ![]() |
#9 |
From what I understand you can contact Chrysler and give them your VIN number and they will send you the blueprint for your vehicle from when it was manufactured. It will show everthing that was installed on your Jeep at the factory. I can't confirm this but I read about it on the Jeeps Unlimited forum just the other night. Anyone else know about this?
#10 | |
Thank you...this was the type of info I was looking for, just wasn't too sure. Just to clear things up...I wasn't "bragging" that I could spin both tires in wet grass or saying that stock YJ's came with LS option (although that would be good to know). I was curious to see if that meant anything concerning MY particular rear end setup.Thanks! "Jeff Gordon" <93 YJ, 4.0, 4" Skyjacker lift, 1 1/4" Daystar greasable shackles, 33" BFG A/T, Herc'd interior, Herc'd full doors, trac/sway bar delete, custom primer/gloss black> <80 CJ5, bone stock, fully restored> *SOLD* |
#11 |
Better way to test for limited slip/locker/trac-lock etc...
OPEN THE DIFF ![]() |
#12 | |
Here's my build sheet... Thank you for your email to DaimlerChrysler Motors Corporation regarding your 1991 Wrangler. According to our records, your vehicle was equipped from the factory with the following: Premium Cloth Bucket Seats Convenience Group Leather Interior Group SE Decor Group Value Plus LE Group Monotone Paint 75 Amp Alternator 430 Amp Maintenance Free Battery Power Front Disc/Rear Drum Brakes High Back Bucket Seats Reclining Front Seats Rear Folding Seat Floor Carpet Cargo Compartment Carpet Full Length Floor Console All 3-Speed Automatic Transmissions 3-Spd. Automatic 32RH Transmission Command-Trac Part Time 4WD System Dana 30/186MM Front Axle 3.55 Axle Ratio Dana M35/194MM Rear Axle Anti-Spin Differential Rear Axle 4.0L Power Tech I-6 Engine Tinted Windshield Glass Plastic Front Door Window Half Metal Doors with Locks Left Manual Mirror Right Manual Mirror Swing-Away Mirrors Heater w/Instrument Pnl Ventilation 100 MPH Primary Speedometer Digital Clock Var Intermittent Windshield Wipers Cigar Lighter Locking Glove Box Courtesy Lamps Underhood Lamp Halogen Headlamps Painted Front Bumper Black Rear Bumper Sport Bar w/Side Padding California Emissions EVAP Control System 20 Gallon w/Tethered Cap Fuel Tank Heavy Duty Engine Cooling Prowler Red Clear Coat Prowler Red Clear Coat All Radio Equipped Vehicles AM/FM Radio 2 Speakers Power Rack and Pinion Steering 2-Spoke Soft Feel Steering Wheel Standard Duty Shock Absorbers Rear Shock Absorbers Tilt Steering Column Full Size Spare Tire Outside Tire Carrier P215/75R15 OWL All Terrain Tires
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards... |
#13 |
That's pretty cool!!! do you have a link to where I can send my VIN?
Dan |
#14 |
Try this one. Click "send us an email."
http://www-5.jeep.com/webselfservice/jeep/index.jsp?screenName=customer&country=us&emailUrl= goToEmailForm%28%27R%27%29
#15 | ||
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
