Both rear turn signals coming on. - Page 3 - JeepForum.com
post #31 of 42 Old 05-14-2013, 05:46 AM
Rproject
1987 YJ Wrangler
Originally Posted by ad-man View Post
Found it. I am SO PISSED OFF at this POS I am going to bed before I blow the fu thing up. I hate this pos heep.
ROFLMAO!!!
Inquiring minds want to know.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #32 of 42 Old 05-14-2013, 07:06 AM
RustyNutts
lmao too
I am also interested in hearing the culprit.
I have been thinking something with the hazard switch, referencing one of ad-man's first posts about this
problem starting after activating the hazard switch.
RustyNutts is offline
post #33 of 42 Old 05-14-2013, 07:14 AM
Que89YJ
If both were lighting it ad to be a hazzard issue. Come on, dont leave us hanging. What was it?
Que89YJ is online now
post #34 of 42 Old 05-14-2013, 07:14 AM Thread Starter
ad-man
1989 XJ Cherokee
Ok I am still pissed but it was a third brake light that the PO had installed and I actually cleaned up and fixed. I didn't notice that it was wired to both sides. Now it only blinks with the left signal. I could live with that, now the key won't turn off or come out, the dash lights won't come on and the idle tubes seem plugged again!!!
I hate this heep!
ad-man is offline
post #35 of 42 Old 05-14-2013, 07:40 AM
bigbossd1030
I hate this heep!
Ill give you 50 bucks! Lol at least you got one figured out
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #36 of 42 Old 05-14-2013, 07:46 AM
Que89YJ
Key is the rod for the ignition switch on the steering column. Dash lights is the fuse or the connector not seated. You are almost there. What year is this Jeep?
post #37 of 42 Old 05-14-2013, 08:04 AM
Rproject
1987 YJ Wrangler
You didn't accidentally hit the tilt wheel lever while you had the compression lock plate out did you? That can cause all kinds of nightmares inside the column.
1996 White ZJ
Rproject is offline
post #38 of 42 Old 05-14-2013, 08:07 AM
Rproject
1987 YJ Wrangler
Since the third brake light was not required on trucks until 1994 (1986 on cars), you can pull it and go back to a factory setup.
1996 White ZJ
Rproject is offline
post #39 of 42 Old 05-14-2013, 09:27 AM Thread Starter
ad-man
1989 XJ Cherokee
Its an 87. The third light will be smashed then swept up and in the garbage by sundown.
I did a lot of moving around of the tilt and had the whole column loose trying to get the plug out for the switch swap. I may have also over tightened the steering wheel when I put it back on. But in my mood last night I may have to replace the column now. The carb is what is really pissing me off. I have had it apart 3 times in the last week fir plugged tubes and stuck floats. Its got to go also. I have replaced fuel hoses and put a new huge filter under the hood. I have had this thing over 2 months now I think and have yet to enjoy it at all. Dont even have.plates on it yet. Cant trust it enough yet to take it to dmv.
Well like you said one more issue down. Thanks to everyone for your help and advice.
ad-man is offline
post #40 of 42 Old 05-14-2013, 09:45 AM
Rproject
1987 YJ Wrangler
I know how you feel. Been there, done that, tried to buy napalm. LOL. The corner will come.
1996 White ZJ
Rproject is offline
post #41 of 42 Old 05-14-2013, 09:48 AM
RustyNutts
"Its an 87. The third light will be smashed then swept up and in the garbage by sundown."
Awesome. You'll feel better after smashing the light. I did a cell phone like that one time, and it was the best thing
that could've happened to that phone.
Keep on keeping on, ad-man.
post #42 of 42 Old 05-14-2013, 09:59 AM Thread Starter
ad-man
1989 XJ Cherokee
I have a gas can in the garage. I think one more drink and I just might have pushed it.in to the street and sparked it up. I was pretty much way off center by the end of the night. I think I will just let it sit for a few days.
ad-man is offline
