borla header - JeepForum.com
post #1 of 7 Old 08-09-2010, 06:50 PM Thread Starter
jth0033
1987 YJ Wrangler
borla header
i found a guy on craigslist today selling a borla header for a reasonable price. has anyone done this install on the 4.2l engine? hows it sound? difficult to install? any and all info appreciated. thanks
jth0033 is offline
post #2 of 7 Old 08-09-2010, 08:46 PM
geocraig77
I did not do the install but have a borla header on my jeep with a cat back and superflow muffler. It sounds good, maybe a bit too loud with this setup. Wish I could give you more info but after no hits I thought I'd throw you a bone.
geocraig77 is offline
post #3 of 7 Old 08-09-2010, 09:08 PM Thread Starter
jth0033
1987 YJ Wrangler
thanks for the bump... anyone else? i know someone has to have this done
jth0033 is offline
post #4 of 7 Old 08-09-2010, 10:37 PM
tyrap26
didnt do it on mine but ive done manifolds on other cars, tricky not hard just got to know what your doing. you need the right tool and knowledge. make sure you dont break any studs or bolts in the head... might need torches, pb blast, patience....take your time, everything is doable. and also keep doing research.
also borla are good quality exhaust system...wouldnt be scare to go with that. know plenty of people that put them on.. so far didnt hear anything bad..
tyrap26 is offline
post #5 of 7 Old 08-09-2010, 10:42 PM
tyrap26
""How-to: Replace your cracked exhaust manifold"" copy that in seach..
you could use that as a guide... but thro on your borla instead..
tyrap26 is offline
post #6 of 7 Old 08-09-2010, 10:57 PM
Cool92yj
Took me about 4 hours to take off weld and put back in it sucks make sure you have ratchet wrenches.
1992 YJ 2 Inch BDS Lift, 35 Pro Comp MT'2s, NV3550, ford 8.8,
Lockrights, Metalcloaked, built 4.0.
Cool92yj is offline
post #7 of 7 Old 08-09-2010, 11:58 PM
jbolty
jbolty's Avatar
I have a borla and between that and a flowmaster muffler it made a noticeable improvement in performance. But the front drive shaft hits it so I am having a custom exhust guy cut/bend/do something to get me some room. Taking it in on wednesday.
jbolty is offline
I NEED A Borla Header Jeeperz89 YJ Wrangler Technical Forum 3 11-05-2002 06:48 PM
borla header badams TJ Wrangler Technical Forum 2 11-04-2002 04:03 PM
Borla Cat-back/borla Exhaust Header Poseidon17 TJ Wrangler Technical Forum 2 09-19-2002 05:33 PM
Borla header mudcat TJ Wrangler Technical Forum 0 08-02-2002 03:43 PM
Borla Header! spgsig YJ Wrangler Technical Forum 5 02-26-2002 02:49 PM
