Borla on a 4.2?? - JeepForum.com
post #1 of 23 Old 06-28-2011, 07:52 PM Thread Starter
Collin89Sahara
Borla on a 4.2??
How do you feel about the cat back system for the 4.2L??
Collin89Sahara is offline
post #2 of 23 Old 06-28-2011, 07:58 PM
4.7stroker
A whole lot of money for very little gain.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 23 Old 06-28-2011, 08:28 PM Thread Starter
Collin89Sahara
Do you run an exhaust? If so what system?
post #4 of 23 Old 06-28-2011, 08:43 PM
jeep16
i run a dynomax super turbo exhaust. it is just loud enough,,, and it sounds great. i would highly recommend it.
jeep16 is offline
post #5 of 23 Old 06-28-2011, 08:50 PM Thread Starter
Collin89Sahara
Butt dyno gains??
post #6 of 23 Old 06-28-2011, 08:51 PM
jeep16
probably a couple horses and a couple pound feat. its alot better if you also run a header.
jeep16 is offline
post #7 of 23 Old 06-28-2011, 08:57 PM Thread Starter
Collin89Sahara
I don't have the money for the headers as I am going to do other mods. I deffinitley know that headers would yield more gains because stocks headers are clunky and restrictive.. The designs of headers on the market are good but certainly could become better. Header length, way header is bent, diameter of the tubes in certain places, and most inportant the material... Hmmm maybe new header design if I could weld!!!
post #8 of 23 Old 06-28-2011, 09:02 PM
jeep16
you can get a header for around 350 and a dynomax for around 140. not too much more than a borla. its all up to you though. i am running a pacesetter header with the dynomax and a 2 barrel empi carb. low end torque is great.
jeep16 is offline
post #9 of 23 Old 06-28-2011, 09:06 PM
4.7stroker
For $500 you can install a 4.0 head and cheap manifold and gain wayyy more than you ever would by fooling with the exhaust.
Dwayne
[url]
[url]
post #10 of 23 Old 06-28-2011, 09:08 PM
jbolty
jbolty's Avatar
I got a borla header for super cheap but I would not spend retail money on it. There was a little noticeable gain in HP but not enough to worry about
jbolty is offline
post #11 of 23 Old 06-28-2011, 09:16 PM Thread Starter
Collin89Sahara
I mainly want it for sound, my friend has the borla on his YJ, it sounds great. I have thought about the 4.0L head, but I have other mods that to do. But if I do have the $ for the head. What goes into putting the new head on? I don't have to rewire anything do I?
post #12 of 23 Old 06-28-2011, 09:24 PM
4.7stroker
I am not in the camp of throwing a lot of money at things to make them sound good, no gain =no cash from me.
Dwayne
[url]
[url]
post #13 of 23 Old 06-28-2011, 09:31 PM Thread Starter
Collin89Sahara
Dwayne what are the steps in order to replace 258 heads with the 242 heads?
post #14 of 23 Old 06-28-2011, 09:36 PM
4.7stroker
http://www.northeastsurf.com/4.0%20head%20swap.htm
Dwayne
[url]
[url]
post #15 of 23 Old 06-28-2011, 09:55 PM Thread Starter
Collin89Sahara
That's a great build up, It has sat in the back of my mind for the month that I have owned my jeep to be able to do this type of modification. When pay day comes, working all summer I will have money in hand then, it will be something that I will have to consider and sleep on. Do you think it would be easy for someone that has never torn into an engine?
PSA: Borla exhaust for 87-91 Wranglers 40% OFF from Borla directly MEinSoCal YJ Wrangler Technical Forum 12 02-06-2008 02:42 PM
Borla? Trebor YJ Wrangler Technical Forum 2 08-29-2006 11:36 PM
Borla Off-Road Kid TJ Wrangler Technical Forum 7 03-03-2003 03:15 PM
Borla Cat-back/borla Exhaust Header Poseidon17 TJ Wrangler Technical Forum 2 09-19-2002 05:33 PM
Tfx vs. Borla tufmar YJ Wrangler Technical Forum 1 08-12-2002 02:35 AM
