Boomerang shackles - JeepForum.com
post #1 of 10 Old 03-03-2013, 12:03 PM Thread Starter
jonny93yj
Boomerang shackles
Getting ready to install my new springs but not sure about shackles?
Short side up?
Or long side up?
jonny93yj is offline
post #2 of 10 Old 03-03-2013, 12:38 PM
roadyrob
1987 YJ Wrangler
I run mine long up in rear, short up in front but pointing in, not out like you are holding them.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #3 of 10 Old 03-03-2013, 01:18 PM
jbolty
jbolty's Avatar
long up in back, long down in front. pointing to center of jeep on both ends.
like this
jbolty is offline
post #4 of 10 Old 03-03-2013, 01:21 PM
Jeffro06
Jeffro06's Avatar
Jeffro06 is offline
post #5 of 10 Old 03-03-2013, 06:07 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Damn. I know I should be complementing the Jeep(it is very nice) but I'm stuck on how good the pictures are. Both are very nice.
Michaelgoesrawr is offline
post #6 of 10 Old 03-03-2013, 06:28 PM Thread Starter
jonny93yj
Got it. Thanks for the help guys! I started throwing stuff on this month, SYE, D/S, OME springs and of course my shackles. Pretty psyched to feel the diiference when it's all done. I used 36r's front and rear and was wondering if how other folks have corrected this little problem.
It seems fine on jack stands but under load I'm thinkin this will be an issue. Am I wrong? Can I just cut the tabs down? I don't know why they'd be there unless it's so you can add a leaf, dunno.
post #7 of 10 Old 03-03-2013, 06:50 PM
Reno72
Those tabs give your springs room to flex while the top bolt keeps them from coming apart. It's part of the reason they ride so nice compared to leafs that are pinched together with a clamp, don't mess with the springs you got good ones. If you haven't put the shackle's on those should give you some more room.
Reno72 is offline
post #8 of 10 Old 03-03-2013, 08:00 PM
NonRubicon
Unless you have something wrong with your axle and steering components, it should fit just fine. I have 36R's on all four with 5/8" lift shackles and for the front axle the only thing I did to the springs was remove the shim. You can loosen and twist the drag link bolt/clamp into a better position for more clearance if desired.
NonRubicon is offline
post #9 of 10 Old 03-03-2013, 08:57 PM
muddigger95
Not to jump your thread, but how do you know what length you need to keep your current ride height? Is it from center to center of bolts holes? Just donno .
Here, hold my beer and watch this SxxT
muddigger95 is offline
post #10 of 10 Old 03-04-2013, 05:33 AM Thread Starter
jonny93yj
This is what I was going to look into once everything is on and on the ground. Thanks again for all the input. As far as telling length for height I'm not sure.
