bomerang shackles in rear installation help - JeepForum.com
post #1 of 18 Old 01-14-2014, 03:37 PM Thread Starter
Cuesoccer24
does anyone know a trick or an easy way to remove the stock shackles and install new boomerangs in the rear of a YJ? I wasn't able to remove the stock shackles because of the gas tank...just wondering if there was any trick to it or not.
Cuesoccer24 is offline
post #2 of 18 Old 01-14-2014, 03:44 PM
Jeepsr4me
jack the rear of jeep up using the frame and let the axle and spring dangle. It will put the bolt where you can get it out. Or cut it and get another bolt.
Jeepsr4me is offline
post #3 of 18 Old 01-14-2014, 03:49 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You may have to cut the bolt or destroy the bushings to get the bolt out. I suggest a sawzall and buy a set of grade 8 replacement bolts.
Luck Favours The Prepared
Anticanman is offline
post #4 of 18 Old 01-14-2014, 04:20 PM Thread Starter
Cuesoccer24
Ya that's what I figured at first just wasn't sure if it was logical to cut right next to the fuel tank just incase of sparks or cutting the tank by accident.
post #5 of 18 Old 01-14-2014, 04:55 PM
Mark05059
as long as you have no leaks your fine.. also stick a wet rag in the tank filler.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 18 Old 01-14-2014, 05:00 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
Like mentioned above, let the springs droop. I had a heck of a time with mine, more-so getting the new bolts in. Id suggest a 6 pack and a BFH. Maybe a prybar or 2. When installing you can use a scissor jack between the spring and frame(carefully) to get it in the perfect spot.
-April '14- YJoTM- June '15
The_Goob is online now
post #7 of 18 Old 01-14-2014, 08:08 PM
jeepguy85
1987 YJ Wrangler
x2 sawzall and a Dewalt fire and rescue blade cut through the bolt in under 10 seconds!
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #8 of 18 Old 01-14-2014, 08:29 PM Thread Starter
Cuesoccer24
Thanks guys...just have to find time from work to do it
post #9 of 18 Old 01-14-2014, 09:29 PM
95yj0645
***** and a half to get the upper bolts out.... I just used a big pry bar once I got the bolt head driven back far enough I could get behind it. I just pried out and toward the bumper. It rubbed the gas tank but it flexed it enough to pop out.
95yj0645 is offline
post #10 of 18 Old 01-15-2014, 09:22 AM
gunshw301
I found it easier to just drop the tank. Sounds like a lot of work, but it really is not that difficult. Once it's down you can do a few more free/cheap mods while your in there if you wish.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #11 of 18 Old 01-15-2014, 09:26 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It's not always easy to drop the tank
post #12 of 18 Old 01-15-2014, 12:56 PM Thread Starter
Cuesoccer24
All the suggestions sound good so thank you.
Anticman...that's a great shot.
post #13 of 18 Old 01-15-2014, 01:05 PM
gunshw301
Okay, maybe not the first time! But after that it is not so bad. I could probably have my tank off in no time. Hell, one rough evening I think I had it in and out three or more times while trying to get my tank tuck and exhaust to play nice with the tub. It's an experience thing, of you don't do it, it will never get easy.
post #14 of 18 Old 01-15-2014, 08:50 PM
konadubrock
I installed my boom. shackles in a few hours using this trick http://www.jeepforum.com/forum/f12/t...ack-yj-809391/
konadubrock is offline
post #15 of 18 Old 01-15-2014, 09:03 PM Thread Starter
Cuesoccer24
That's a good trick I'll have to try that if I can't find a torch or angle grinder
