Bolts - JeepForum.com
post #1 of 12 Old 08-09-2010, 01:01 AM Thread Starter
4x4Hawaii
Bolts
Hey...does anyone know a good way to loosen the bolts for the roll cage? mine are pretty rusted and i wanna take my cage off, fix some rust holes and then put bed liner over everything
4x4Hawaii is offline
post #2 of 12 Old 08-09-2010, 06:36 AM
Area.3.Fiftyone
Weld a nut on top of the Torx and hopefully spin them out with a socket.
Most likely you will strip the Torx. They almost always do.
The heat from welding the nut on also helps in removing them if you do it before the bolts cool down.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #3 of 12 Old 08-09-2010, 09:36 AM
idaholtby
These bolt heads are fat enough to allow a good set of vise grips to get a good bight on them as well. Worked for me.
idaholtby is offline
post #4 of 12 Old 08-09-2010, 09:45 AM
jbolty
jbolty's Avatar
Heat, pb blaster and patience are your friend. An impact tool of the air type or hammer type may help as well but use short bursts to try rattling them loose rather then twisting the head off or spinning the tool.
I think most of them are torx size T45. I found a cheap set of bits at autozone that included a size T47 and I was able to pound that in and get mine out without stripping. The good news is that if you have to drill they are not too hard to get at from the bottom.
jbolty is offline
post #5 of 12 Old 08-09-2010, 09:59 AM
Area.3.Fiftyone
Don't be surprised that when (and if) you start spinning them that some pieces of your body panels don't come along with them.
They are notorious for rusting through behind the lower legs.
post #6 of 12 Old 08-09-2010, 10:04 AM
SloppyJoseph
I used my impact.
SloppyJoseph is offline
post #7 of 12 Old 08-09-2010, 10:46 AM
ehowes12
i grinded mine off (:
ehowes12 is offline
post #8 of 12 Old 08-09-2010, 10:54 AM
ehowes12
aerokroil will never let you down.
ehowes12 is offline
post #9 of 12 Old 08-09-2010, 11:23 AM
giggityjeeper
eletric impact works AWSOME... took everyone of mine out so far.
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #10 of 12 Old 08-09-2010, 11:26 AM
Louie4
I did this after snapping my T45 bit and it worked. I'm sure it didn't help that the bolt was covered in Herculiner.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #11 of 12 Old 08-09-2010, 03:00 PM
19OlllllllO41
19OlllllllO41's Avatar
All you need is heat and a good impact. I just took my roll bar out of my '93 last week. At first I tried to just use my impact, but none of them would budge. I then used a torch to heat the bolts from the backside (everyone is easily accessible), and then hit them with the impact again...they all zipped right out with out any trouble. The heat is by far the secret IMO. I think there is some factory thread locker on the threads and the heat loosens it. Also the impact is important because you can put a lot of downward pressure on the torx so it wont strip out. Often they strip simply because people use a ratchet and don't use enough downward force. One last tip is to make sure there is no factory "caulk/sealant" on the threads. On my Jeep they went crazy with the sealer and it was on the threads of a few bolts, so I used a wire wheel on my dremel to clean it off before I removed them. Good luck!
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #12 of 12 Old 08-09-2010, 03:59 PM
No-Doors
If you don't have access to an impact or welder (like me) - use a dremel to cut part of the head off on opposite sides. This gives you two flat surfaces. Then heat with a torch, then put your vice grips on and presto - it will break loose. Had to do this on six of my roll bar bolts yesterday. Worked every time.
A Rancher told me that back home he can drive his Jeep all day and not get off his own property; I said "I've got a Jeep like that too"!
"Nothing sucks more than that moment during an argument when you realize you're wrong" (Paul :-Ž)
No-Doors is offline
Torque converter bolts- can I use regular bolts? dodgetk81 TJ Wrangler Technical Forum 5 07-08-2010 05:21 AM
Want to replace stock control arm bolts with grade 8 bolts... Mino TJ Wrangler Technical Forum 7 01-23-2010 10:02 AM
Torx head starter bolts - Anyone know what kind of bolts? patricknolan TJ Wrangler Technical Forum 0 08-13-2009 08:02 AM
Tool for taking off hardtop bolts and windshield hinge bolts TheDiabetic TJ Wrangler Technical Forum 10 03-30-2006 05:49 PM
Removal of snapped body mount bolts and bolts in general? SpedJeep YJ Wrangler Technical Forum 15 10-16-2005 09:01 PM
