Bolt for power steering pump - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Bolt for power steering pump
Savvy Aluminum Gas Tank SkidFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Stainless Steel Door Hinge Pins
Unread 08-07-2014, 11:36 AM   #1
MukYJ
Pronounced "Mucky J"
MukYJ's Avatar
Hey all,
I opened the hood on my YJ the other day and was surprised to see the top bolt that was supposed to be holding on my power steering pump was missing!
I think the head size was 13mm, but does anybody know what the thread size is on that bolt? Hopefully I'll be able to find a replacement at the hardware store...
It's the one listed as the Pivot Bolt in the attached parts diagram.
~/Garth - 1993 Wrangler S 2.5
{ }|||||||{ } "MukYJ"
He's right, as soon as you remove the trackbar the fuel rail will arc on the battery, killing you and all the kittens in a ten mile radius.
MukYJ is offline   Reply With Quote
Unread 08-07-2014, 11:45 AM   #2
superj
1987 YJ Wrangler
its a normal old bolt. i just took my pump off the other day. its not a fine thread or anything. its the same as the bolts holding the windsield or tailgate on, just a regular head instead of a torque head. well, and its longer but the thread pitch and type is the same
Slow ride, take it easy
superj is offline   Reply With Quote
Unread 08-07-2014, 09:11 PM   #3
Opihi59
from here it gets rough
Opihi59's Avatar
Find a 5/16 18 and try it without forcing. Should be the right size/pitch.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://kamfamily.wordpress.com/2009/...waiian-limpet/
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline   Reply With Quote
