Bogging out in 4 high - Page 2 - JeepForum.com
post #16 of 17 Old 08-16-2011, 09:17 PM
Old4X
1990 CJ7
As mentioned earlier, plug the vac line going to the vac switch on the transfer case. You aren't using it (the vac disconnect) anymore, but may be creating a large vac leak when selecting 4 X 4 in the transfer case and the vac switch is still plumbed to the engine..
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #17 of 17 Old 08-17-2011, 03:25 PM
USMC3531
I agree with Old4X.....I pulled the entire vacuum line harness out when I switched to the Posi-Lock and plugged the main vacuum line from the engine to the 4 wheel vac system.
USMC3531 is offline
Bogging down Fire829 TJ Wrangler Technical Forum 0 10-04-2010 10:22 AM
Bogging down when hot Photojeep TJ Wrangler Technical Forum 8 11-02-2009 09:50 AM
Bogging out on climb w/ high RPM doubleup TJ Wrangler Technical Forum 21 10-22-2009 01:57 PM
99 TJ 4.0 bogging.... petej200 TJ Wrangler Technical Forum 2 02-28-2009 10:14 AM
Bogging in High REV 89yjester YJ Wrangler Technical Forum 13 02-01-2007 06:24 PM
