Bogging out in 4 high - JeepForum.com
post #1 of 17 Old 08-13-2011, 07:32 AM Thread Starter
calebrandal
Every time I try to use 4 high to climb even the smallest grade the engine boggs down and stalls. It doesn't do it in 4 low. Could it be a vacumn leak. I no longer have the vacumn actuated set up. Maybe the PO forgot to plug something? Any Ideas??
calebrandal is offline
post #2 of 17 Old 08-13-2011, 11:12 AM
srdart67
I would start with checking for vaccuum leaks and if nothing check your transfer case linkage to make sure you are going all the way into gear.
srdart67 is offline
post #3 of 17 Old 08-13-2011, 02:24 PM
MJMPC
What speed and RPM are you hitting the bottom of the hill?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 17 Old 08-13-2011, 02:33 PM
Xpress
Does it do the same in 2wd?
All about that unibody life.
Xpress is offline
post #5 of 17 Old 08-13-2011, 02:44 PM
giggityjeeper
maybe it just needs gears and it cant climb the hill in 4th..... vacuum leak would give ya grief all the time I would think.....
since the tire upgrade 4th and 5th are nonusable in mine pretty much till I get gears
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #6 of 17 Old 08-13-2011, 03:06 PM Thread Starter
calebrandal
does not stall in 2wd
post #7 of 17 Old 08-13-2011, 03:07 PM Thread Starter
calebrandal
usually pretty slow
post #8 of 17 Old 08-13-2011, 03:24 PM
Xpress
Might be something up with your vacuum disconnect system if it doesn't stall in 2wd. I'd say go through all of your vacuum connections going to the t-case, the vacuum switch on the t-case, and then the lines running to the shift motor. Either that or plug up the manifold vacuum that operates these and get a posi-lock system.
Xpress is offline
post #9 of 17 Old 08-13-2011, 03:28 PM
giggityjeeper
he dont have a vacuum system anymore..... Im guessing he has a posi...
im gonna go with it dont have enough power to turn the 4 tires in high range.... if its the vacuum it will do it all the time low range or high, you have a posi kit??... pull cable style?
off road, mine is LOW RANGE only, it wont turn my 33 in 2nd gear off raod let alone 4th.....
nothing really to unhook vacuum wise that would make your jeep run bad..... you need gears is my thinking, as it runs down the RPM, it will start to buck and stall out.......
post #10 of 17 Old 08-13-2011, 03:34 PM
Alext13
Not enough power in 4 high, to much strain on the drivetrain. Time to buy gears
Alext13 is offline
post #11 of 17 Old 08-13-2011, 07:43 PM
Bigboyky
Whats the condition of your motor? With the 3:07's and 31" tires you should have power to wheel... Now me personally I don't use 4H for anything but on winter/snow covered roads. When I'm, off road it's 4L and I have 4:88 gears! If your're talking steep hill climbs or deep mud then you should use 4L. Just my opinion though
1995 4.0l, 5spd., 4:88's, ARB's F/R, 4"RC lift, homebrew bumpers & tire carrier, homebrew gas tank skid, lined inside, Cobra cb, smitty winch, 130w & 55w Hella lights
Envy our past, Fear our future Go Cats!
Take a look at our club
& here on JF
Bigboyky is offline
post #12 of 17 Old 08-16-2011, 05:26 PM Thread Starter
calebrandal
Yes, have posi-lock.
guess I'l check for vacuum leaks and use low. never had any problem in my S10 with 3.73's and 31's
post #13 of 17 Old 08-16-2011, 06:04 PM
USMC3531
Maybe I''m missing something but the 4 high has nothing to do with gear advantage, it's the same as 2 high, same gearing, just 4 wheel drive. You just need to downshift into a lower gear in high if the hill isn't too steep, or into 4 low for steeper hills. That will give you the gear torque multiplication to keep the motor from bogging.
I think your jeep has 4.10's stock, my 90 does. My little 2.5 with 31's will climb a wall in 4 low with no bogging.
Posi-lock has nothing to do with it, that just locks the halves of the front axles together, giving you 4 wheel drive. And even if your posi-lock wasn't working, that would just make your rear wheels spin, not bog the motor.
USMC3531 is offline
post #14 of 17 Old 08-16-2011, 06:30 PM Thread Starter
calebrandal
it bogs out in 1st gear and 4 high.
not for certain, but you have 410 gears because you have a 2.5
post #15 of 17 Old 08-16-2011, 06:38 PM
USMC3531
Hm, I was missing something.... 1st gear in 4 high range is a different story, although my jeep starts bucking in that gear if the speed gets too low and I try to nurse it along with the clutch. It would die if I kept on in high range. Shifting into 4 low range lets me crawl along without the bucking. Yeah, 4.10's are stock with my 2.5.
USMC3531 is offline
Bogging down Fire829 TJ Wrangler Technical Forum 0 10-04-2010 09:22 AM
Bogging down when hot Photojeep TJ Wrangler Technical Forum 8 11-02-2009 08:50 AM
Bogging out on climb w/ high RPM doubleup TJ Wrangler Technical Forum 21 10-22-2009 12:57 PM
99 TJ 4.0 bogging.... petej200 TJ Wrangler Technical Forum 2 02-28-2009 09:14 AM
Bogging in High REV 89yjester YJ Wrangler Technical Forum 13 02-01-2007 05:24 PM
