Bogging down - JeepForum.com
post #1 of 203 Old 09-16-2013, 07:49 PM Thread Starter
lander2312
Bogging down
Ok did a thread search and found some that kinda hit my problem but lots of people never came back and gave a what finally fixed the problem. I have a 1993 with the 2.5l fuel injected engine. When i give it gas to accelerate sometimes it will just struggle to go....bogging down then others its fine. It was only doing this when the gas got below a 1/4 tank, but today it did it right after i filled it up. I have checked my fuel pressure at the rail and its high if anything. I have replaced the 02 sensor and also put a new fuel filter. The Jeep is no longer throwing any codes. Only think I can think of might be something in the tank??? Anybody have this problem. What do i need to look for and check next?
lander2312 is offline
post #2 of 203 Old 09-16-2013, 07:55 PM
superj
i cant help. never had the 2.5 and mine is carb'd
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 203 Old 09-16-2013, 08:02 PM Thread Starter
lander2312
ummmm thanks Superj....I think
post #4 of 203 Old 09-16-2013, 08:31 PM
jeepyj13
I had this problem recently with my yj 4.0. At hwy speeds in hot conditions it will bog down if driven for a long period of time. I would be doing 65mph and suddenly it feels like a hard wind just hit, but it actually my engine losing power like its out of fuel. If I press the petal harder it will about cut off. I checked fuel pressure and its fine. I replaced distributor cap and rotor, but no good. I then moved on to the map sensor and replaced it. I drove it 40 miles yesterday in 93 degree weather at 65 mph and all was good. That may or may not solve it, but it could be anything tps, map, temp sensor near tstat from what I read up on here. You changed out o2, how about the cat converter? I can't pull any codes on mine because my dash check engine light etc doesn't work. I have a 3sp auto. Hope these suggestions help.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #5 of 203 Old 09-17-2013, 03:36 AM
Que89YJ
What do you mean it's high off anything. 31/39 what did you read? Did you check the fault codes using the key method? Does it make any difference hot/cold?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #6 of 203 Old 09-17-2013, 06:22 PM Thread Starter
lander2312
A mechanic checked the pressure at the rail for me and said that the pressure was on the high side but within specs....don't have the specific number. Yes I used the key code and it was throwing a O2code and I replaced it. Anyone else?
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
George Orwell
post #7 of 203 Old 09-17-2013, 07:04 PM
Apollo12227
Sounds like a spark issue to me... Engine misses upon acceleration... Possibly fouled plugs or plug wires. Possibly the throttle position sensor.
Apollo12227 is offline
post #8 of 203 Old 09-17-2013, 07:06 PM
Apollo12227
Mine did this on 2 seperate occasions. 1 when the throttle position sensor went out, and again when my fuel pump went out due to a crushed return line.
post #9 of 203 Old 09-17-2013, 07:31 PM
jeepyj13
Yep. If I pull over and cut the engine off for a minute if that, then start it back up and resume hwy speed it will do fine for sometime. Then it will start acting up again. I did a tune up no change, then replaced MAP sensor. I've been driving it in hot weather on 70 mile round trip commutes now no problem so far. I've been reading up on here that TPS has alot to do with this as well.
jeepyj13 is offline
post #10 of 203 Old 09-17-2013, 08:12 PM
bigbossd1030
When my TPS went, it was always higher speeds, never residential speeds. Anything over 80kmh. My check engine light never came on. I was on a three hour drive to go camping and it suddenly pulsed if you will. I ignored it thinking it was wind. But then it started doing it every couple of minutes. So I pulled over and unloaded some of our gear into the other truck, thinking that may have been an issue. So we went for another 30mins, then it would do it again. The rpms wouldn't drop enough to show on the tach. And I stopped again. Thought it might have been bad gas. So we went again, and I knew it was something more than gas when we went another 30mins and she did it again. So made it to the site, parked it for 3 days, put in some gas line antifreeze thinking there was water in it. And got about 40mins away from home and the cel came on. Shut off when I pulled in the driveway. Code 24 or 27 I can't remember. Anyway, TPS. Put in a new one and all was good.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #11 of 203 Old 09-17-2013, 08:17 PM Thread Starter
lander2312
I have also replaced all spark plugs and all new wires. It just feels like it is not getting fuel...like i might have trash in the tank or that the pump it getting clogged. What is in the internal parts of the tank/fuel pump that might cause it to cause it to bog down from time to time...there is no rhyme or reason...if its hot or cold. I think I am going to break down and drop the tank...unless someone has any ideas on what I can do to diagnose it without dropping the tank.
post #12 of 203 Old 09-17-2013, 08:24 PM
GrantYJ
It's sounding more like a bad pump. If your mechanic checked it with the engine off (or even at idle) it will check out OK, but you won't know if flow is the problem.
If I'm correct (mine acted just like yours about two years ago), the problem will slowly get worse until it stops for good.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #13 of 203 Old 09-17-2013, 08:30 PM
GrantYJ
Also, inside the tank there is a baffle box (like a tray that the sock filter of the pump picks fuel up from). These things are notorious for breaking (mines been gone for well over a decade). It's possible that a chunk of it could be choking it down, but it's most likely just the pump.
GrantYJ is offline
post #14 of 203 Old 09-17-2013, 09:19 PM Thread Starter
lander2312
Any way to check that out WITHOUT dropping the tank? Just have heard its a pain to drop it....looks like I have found my project for the weekend.
post #15 of 203 Old 09-17-2013, 09:35 PM
bigbossd1030
Inspection camera?
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
