Body Work, Rusting Seat Pan, Safety, and your thoughts.... - JeepForum.com
post #1 of 7 Old 05-31-2013, 02:35 PM Thread Starter
UncleFishbits
Cheers all! 1995 YJ here. Work done on the mechanical side makes it, basically, a new car in every way. But it is a beach / mountain truck that has gotten some pretty aggressive "free spirited" use (as it should be). Caked in dirt, etc. It's getting old.
Just got new rugged ridge seats, new seatbelts, and I am just starting to repair the interiors (slowly), and thinking of doing some cosmetic body work.
After I installed the seats, I noticed a pretty loud crack/pop sound as I drove, and lo and behold... a dilemma. See pics. There is a crack in the seat well / pan area, and I know it is really unsafe, and means real body work, real quick.
I commute with this thing, all over, at this point. Should I assume this is unsafe to the level that I shouldn't be driving it? I know we aren't safe vehicles, but I would sheer off in an accident, likely?
Also, if I get body work done, and spruce it up a bit more than I had planned - is there anything I can do to make this truck safer?
Any advice or thoughts would be really appreciated. Thanks.
I added a few extra photos - the seats are EXCELLENT, but obviously the floor was ready to go upon tightening. Also thought you should see my badass ride. =)
This is sort of depressing, honestly. ha
2013-05-31 11.46.41.jpg   2013-05-31 11.47.18.jpg   2013-05-31 12.23.09.jpg   2013-05-31 12.23.32.jpg   2013-05-31 12.23.44.jpg
UncleFishbits is offline
post #2 of 7 Old 05-31-2013, 05:38 PM
lestes94
The floor underneath my drivers side is probably 3x as bad as that (It was literally collapsed in for about 2x3")... but I never repaired it. I just saw it as this: The seat belts are really all that help you in an accident, not the seats. Since the seat belts are attached to the floor, independent of the seat, then you should be safe. I would be more concerned if my seatbelt was affected, but since it is not, I just slid a 1/4" thick plate under the seat frame and called it good.
'94 YJ: 4.0L HO fi, 5-speed AX-15, Daystar 1.25" shackles, 17" JK wheels, lined tub, custom paint, Bestop Supertop, etc..
'88 YJ: 4.2L carb, 5-speed, stock everything. Banana-ish yellow. hard top. 26,XXX original miles.
lestes94 is offline
post #3 of 7 Old 05-31-2013, 05:55 PM
Mr.ThunderMakeR
^ Uh no offense, but don't listen to this guy. Seats are a really important safety item. This is actually a pretty common problem. Its a design flaw, the seat mounting points are a high stress area and not properly reinforced. I had this same problem. I just took it to a local off road shop and had them weld in some steel plates. Done for under a $100, less than an hour. See my build thread, post 7:
http://www.jeepforum.com/forum/f12/w.../#post14513817
- '91 Jeep Wrangler YJ, 4" lift with 33" BFG KM2's, 1" body lift, NV3550 swap, NP241OR Rubicon TCase w/ Novak Cable Shifter, Monstalined Tub
- '09 Mazda RX-8 R3
Mr.ThunderMakeR is offline
post #4 of 7 Old 05-31-2013, 08:31 PM
gunshw301
Nice thread thanks. I really like the gray interior. I think I might have to copy.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #5 of 7 Old 06-03-2013, 11:28 PM Thread Starter
UncleFishbits
Cheers, and thank you so much. No offense to other guy, obviously, but I was really worried about the nature of inertia and the seat flying off.... if am buckled in, it could mean possibly decapitating me as belt stays stationary while i am moving i the seat.
I got a crazy quote from a local body shop, they love the Jeep and they're really excited to do some work and paint job for a very affordable price. It is a good hairline fracture to have.... it is making me really restore it. Will post pics of progress.
Thanks!
post #6 of 7 Old 06-04-2013, 08:08 AM
Fozzybear42
Which rugged ridge seats are those? They look very nice and I've been waffling over which seats to get for months....
Fozzybear42 is offline
post #7 of 7 Old 06-04-2013, 08:43 AM Thread Starter
UncleFishbits
I am the ultimate waffler. Took me like 5 years to finally pull the trigger. But I'm glad I did the seats are the most comfortable thing I've sat in, well, for 18 years of this truck. Love 'em.
2 *qty 24230 17 07 * * * * * SUPER SEAT VINYL-SPICE * * * * * * * * *13404.37 * * * * 499.98
http://www.quadratec.com/products/24230_XX_PG.htm
safety , seat bolt , seat bracket , weld repair , YJ
