body repair question - JeepForum.com
post #1 of 2 Old 09-12-2011, 07:04 AM Thread Starter
wanabejeeper
1987 YJ Wrangler
Some shots of the rust hole just in front of the Driver Side rear wheel well. The section includes the floor and a small piece of the seatbelt post underneath the seatbelt anchor point.
I've never welded before but I do have a Lincoln Arc 120. Because this section forms a inacessable pocket indside the body there would be no way to paint or otherwise rust proof that area. What would be the best way to do this repair?
I was thinking of welding the floor pan section and the seatbelt post. Painting that area inside and out and then using a fiberglass patch on the outside of the body. Any better ideas? What gauge steel is the body and floor made of?
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #2 of 2 Old 09-12-2011, 07:17 AM
EABiker
3M makes a great panel bonding adhesive that also seals the new seam against rust. Many bodyshops now use it rather than welding; maybe worth a look.
EABiker is offline
body repair CreepyCrawler95 YJ Wrangler Technical Forum 1 04-07-2009 10:36 AM
Looking for some body repair pics.... Char250r Wrangler General Discussion 5 01-16-2009 12:30 PM
Jeep body repair shackkat YJ Wrangler Technical Forum 6 06-10-2007 10:15 PM
Body damage repair/cost question Freakshow TJ Wrangler Technical Forum 5 03-30-2005 05:26 PM
Body Repair mmitsch YJ Wrangler Technical Forum 0 08-01-2004 07:36 AM
