body mounts - JeepForum.com
post #1 of 3 Old 01-20-2002, 11:52 AM Thread Starter
mc87yj
body mounts
I recently tried to put on my 1/2 doors on my project '87 yj.Passenger side is fine.Drivers side wouldn't go.I found top of opening is 1/2" smaller than other side.I loosened body mounts on drivers side,jacked it up and put washers on top of mount and let body down.I gained enough so door will close.Question is,is this a common ocurrence?Can I make new pucks out of aluminum and where could I get the stock thickness specs.?
mc87yj is offline
post #2 of 3 Old 01-20-2002, 04:33 PM
igofshn
Locked @ both ends
igofshn's Avatar
Just buy new body mounts. There are lots of kits out there and they aren't very expensive.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #3 of 3 Old 01-20-2002, 04:35 PM
glm 87 wrangler
Well if no one here can help you.You may try a jeep dealer and see what they think? I would look for free advice dont let them try to talk you into bringing it in.They have a good shop manual that will help.My dealer around here is great.Others in other areas may be to big to help you just depends on were you live.Hope this helps
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
04 tj body mounts TJDaveX TJ Wrangler Technical Forum 7 12-31-2007 08:54 PM
body mounts kimvansa YJ Wrangler Technical Forum 3 01-11-2007 07:16 PM
Cab and Body mounts BoSox04 TJ Wrangler Technical Forum 2 01-08-2006 08:03 PM
the 11 body mounts.. where are they all?? got_4_lo YJ Wrangler Technical Forum 9 11-28-2005 09:10 PM
BODY LIFTS........BODY MOUNTS ONEDIRTYTJ TJ Wrangler Technical Forum 4 07-17-2001 04:01 PM
