Body mount Torque specs? - JeepForum.com
post #1 of 8 Old 06-14-2003, 08:31 PM Thread Starter
mde
Can't find it anywhere. Does anyone know what to torque the body mount bolts?
Thanks guys
89' YJ
AMC 258, all mods
7" SOA BF 35" mud terrain
mde is offline
post #2 of 8 Old 06-15-2003, 12:21 AM
BamaJeeper
BamaJeeper's Avatar
Tighten until the cracks in the rubber bushings look like they did before you removed them.
Out of the darkness comes light.
BamaJeeper is offline
post #3 of 8 Old 06-15-2003, 12:21 AM
lostboy
confusing info in service manual. no specific info given for yj,only for series 10 body which is the grand wagoneer body.
Here's what it says:
body holddown 1,3,4,5 36 ft lbs.
holdown 1 and 2 36 bft lbs
body holddown 1,3,4 55 ft lbs
body holddown2 36 ft lbs
radiator guard hold down 36 ft lbs
as I said ,it sure looks confusing
it looks like the bushings should just bulge a bit when they are correct,so you could use that as a guide
89 yj w/ mopar mpi and 4.0 head.94 ax-15 tranny and t-case, more mods comin.
lostboy is offline
post #4 of 8 Old 06-15-2003, 10:12 AM Thread Starter
mde
thanks
Yeah its brutal. Not too sure what to make of it. I originally tightened them to 80 ft/lbs. Way too much. So anything below 30 should suffice.
Cheers
89' YJ
AMC 258, all mods
mde is offline
post #5 of 8 Old 01-17-2010, 06:12 PM
blue-monster
Cheers
What about the 3" body lift? 80 ft/lbs ok?
blue-monster is offline
post #6 of 8 Old 01-17-2010, 06:25 PM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
hotelconucc93 is offline
post #7 of 8 Old 01-21-2010, 04:08 AM
blue-monster
Originally Posted by hotelconucc93 View Post
i saw it but still no answer
post #8 of 8 Old 01-21-2010, 05:09 AM
hotelconucc93
2010 YJ Wrangler
Um....the body mount bolts are the question, not the height. Same torque.
Body Mount Torque Specs? JBWood05TJ TJ Wrangler Technical Forum 2 09-07-2009 05:42 PM
Body mount torque specs? 04JeepTJ TJ Wrangler Technical Forum 9 06-04-2005 01:45 PM
Body mount torque specs.... Ryans_GP YJ Wrangler Technical Forum 0 11-26-2004 10:53 PM
Body mount torque specs? blackw YJ Wrangler Technical Forum 11 04-27-2004 12:41 PM
body mount torque specs Bucket110 TJ Wrangler Technical Forum 3 08-23-2003 01:26 AM
