Body Mount Bolts - JeepForum.com
 3Likes
  • 2 Post By Randonexplosion
  • 1 Post By DirectMatrix
post #1 of 13 Old 10-19-2017, 08:43 PM Thread Starter
KidWithaYJ
Body Mount Bolts
I have good body mount rubbers/bushings etc, just need the set of bolts. Where does everyone get them and how many ea of what sizes?
Thanks
KidWithaYJ is offline
post #2 of 13 Old 10-19-2017, 11:42 PM
lclark2074
lclark2074's Avatar
i use http://www.boltdepot.com good prices and good selection
night crew 226
lclark2074 is offline
post #3 of 13 Old 10-20-2017, 02:45 AM
Bigmaaty
1979 CJ7
I bought grade 5 from the bulk bins at Tractor Supply. Could have gone grade 8 for a few dollars more but figured 5 was as strong as the frame they are going in. Less than $10 for all including washers. Sorry I didn't write down the measurements. Can you pull out the ones you have? I just pulled mine out from one side and under the radiator and took them with me.
Bigmaaty is online now
post #4 of 13 Old 10-20-2017, 06:00 AM
jbolty
jbolty's Avatar
what he said ^ they are just 1/2 x13 bolts, nothing special. they are screwed into stamped nuts that are little more than sheet metal so grade 5 is plenty.
jbolty is offline
post #5 of 13 Old 10-20-2017, 07:49 AM
DirectMatrix
Do you buy the assortments or just what you need, when you need? I'm so tired of running out to the hardware store just for a few nuts, bolts and washers.
~DM
92 YJ, Delilah
DirectMatrix is offline
post #6 of 13 Old 10-20-2017, 08:37 AM
Jeepsr4me
~DM
If you got another way to the store, take all the bolts out of one side of jeep ONE SIDE and compare and bring what you need to get the new bolts. Think there is a couple different sizes, specially the ones up under the jeep near the front of fuel tank and behind it.
I also use anti seize on them.. as mentioned above they screw into a flat chunk of metal with threads cut into it.
Below is a supply list for a 1 inch body lift.. subtract 1" and those are the ones you need
6 Bolt 1/2-13X4.5Hex
5 Bolt 7/16-14X3.5Hex
Jeepsr4me is offline
post #7 of 13 Old 10-20-2017, 09:09 AM
Randonexplosion
Randonexplosion's Avatar
They are the same for our YJs
-OIIIIIIIO-01 and bruinjeeper like this.
Randonexplosion is offline
post #8 of 13 Old 10-20-2017, 09:10 AM
DirectMatrix
I was asking generally if the user who posted the link for the bolts buys them in bulk...not specifically for body bolts. Mine body mounts have been done for a while
bruinjeeper likes this.
92 YJ, Delilah
post #9 of 13 Old 10-20-2017, 09:46 AM
-OIIIIIIIO-01
Mall Rated
-OIIIIIIIO-01's Avatar
91 YJ 4.0/AX15/231J AA SYE/ Tom Woods CV
3.5" BDS Springs / .75" Booms / 1"BL
HP D30 /Akebono's /1 Ton GM Crossover Steering
Ford 8.8 / Trac loc LSD w/ disc brakes
35x12.5x16 Nitto Trail Grapplers
Walbro255 MetalCloaks
-OIIIIIIIO-01 is offline
post #10 of 13 Old 10-21-2017, 08:03 AM Thread Starter
KidWithaYJ
Thank you so much. The bolts at the hardware store don't have as much thread as these do. Do you use more than the hardware store threads?
post #11 of 13 Old 10-21-2017, 08:04 AM Thread Starter
KidWithaYJ
Did you need the extra thread that the factory style have or did the regular thread length work?
Thanks
post #12 of 13 Old 10-21-2017, 08:33 AM Thread Starter
KidWithaYJ
Also, does anyone have a diagram or guidance on how the body mounts/washers/etc go together?
post #13 of 13 Old Yesterday, 11:42 AM
Randonexplosion
The amount of available thread was plenty. Most of the bolt is shouldered where it runs through the bushings. I did 1/2" lift spacers so I got them 1/2" longer than the ones in the picture.
