Body Mount Bolts - JeepForum.com
post #1 of 2 Old 08-14-2011, 02:59 PM Thread Starter
wallyJEEPIN
Body Mount Bolts
I was installing a 2inch body lift on my 91 YJ well the front body mount bolt (under the grill) brock any ideas how to get it out?
wallyJEEPIN is offline
post #2 of 2 Old 08-14-2011, 03:20 PM
Firefyter-Emt
That bolt should be going into a square plate held in a cage. If you cut the cage on once side, you should be able to get it out. I think the YJ grille had a sheet metal cover that went over it, right? You may be able to pry it up enough to get it out.
Firefyter-Emt is offline
Body Mount Bolts Skydmark1 YJ Wrangler Technical Forum 4 07-24-2011 06:34 PM
Removal of snapped body mount bolts and bolts in general? SpedJeep YJ Wrangler Technical Forum 15 10-16-2005 09:01 PM
body mount bolts bigjeep39 YJ Wrangler Technical Forum 0 11-03-2004 07:50 AM
Body Mount bolts Bucket110 TJ Wrangler Technical Forum 0 01-04-2004 03:38 PM
