Body Mount Bolt Sizes? - JeepForum.com
post #1 of 12 Old 04-16-2013, 12:26 PM Thread Starter
Sparrows
Ok so I'm going to be removing the BL (put on by the PO) and just dropping it back down onto the stock mounts. I've been searching for the last two+ hours trying to find out what size of bolts I'll need (length, diameter, threads, etc) so I can go pick up some new ones.
Checked the FAQs, searched the forums, and bowed before the mighty Google with no luck. Anyone have an answer to this? Pretty much looking for the dimensions of the stock bolts. Far as I can tell there are two sizes? The 6 under the rockers appear to all be the same, and the ones by the fuel tank, rear bumper, and under the radiator all seem to be the same too?
Thanks.
Cheers
June '13 YJOTM
Sparrows is offline
post #2 of 12 Old 04-16-2013, 12:36 PM
kostyanj
Please post the answer if you find it. I need to replace mine as well.
kostyanj is offline
post #3 of 12 Old 04-16-2013, 12:52 PM Thread Starter
Sparrows
Roger that.
Cheers
June '13 YJOTM
Sparrows is offline
post #4 of 12 Old 04-16-2013, 04:08 PM
Gage56
DAM i just picked all mine up the other week but i forget what size and thread they are
but you are right the 2 rears are shorter than the other 6
1992 YJ
Gage56 is offline
post #5 of 12 Old 04-16-2013, 04:19 PM Thread Starter
Sparrows
Got the receipt? Haha
Cheers
June '13 YJOTM
Sparrows is offline
post #6 of 12 Old 04-16-2013, 04:25 PM
Gage56
Cheers
LOL Yeah but it was a bulk buy
1992 YJ
Gage56 is offline
post #7 of 12 Old 04-16-2013, 07:50 PM
brzehentmaier
brzehentmaier's Avatar
Just put a 1.5 BL on mine for some tire clearance. There are 11 all together. The 6 bolts along the frame in the middle are 3.5" long and are a 1/2-13. The other 5 (1 in the front under rad. 2 by the top of the rear shocks and the 2 in the back) are 2.5" long and are 7/16-14. I have the 6 1/2-13 and only 2 of the 7/16-14. The other 3 broke off which let me play with the cut-off wheel for a while. I could send them to you. Send me a PM with your address and I'll send them off. They aren't the prettiest but still work(heads are perfect and not stripped.
Bernie
1995 Rio Grande
31 x 10.5 x 15 Tires
1.5 Body Lift - Skyjacker Hydros
2.5 - Auto - Crager "D" Slots
A Work In Progress
2004 Liberty Columbia Pkg.
A new begining
brzehentmaier is offline
post #8 of 12 Old 04-17-2013, 09:52 AM
kostyanj
Are those bolt lengths with the body lift or at stock height?
kostyanj is offline
post #9 of 12 Old 04-17-2013, 10:09 AM
Gage56
that should be the stock length 3.5" and 2.5"
1992 YJ
Gage56 is offline
post #10 of 12 Old 04-17-2013, 01:07 PM Thread Starter
Sparrows
Bernie
Thanks so much! That's exactly what I needed!
Thanks for the offer, but I think I can pick them all up for cheap locally. If I run into any problems I'll pm you.
A mod should add that info to the FAQs.
Cheers
June '13 YJOTM
Sparrows is offline
post #11 of 12 Old 04-17-2013, 01:18 PM
kostyanj
I actually want to compile a list of all the bolt sizes on the yj.
kostyanj is offline
post #12 of 12 Old 04-17-2013, 01:44 PM
Gage56
bad thing is i just did that but don't remember what they all are
i got the hinge bolts , roll bar bolts , body bolts , dash bolts and seat bolts
but i do remember like 90% of them were the same
1992 YJ
Gage56 is offline
