Body Mount Bolt Locations (For BL) - Detailed Write-Up W/ Pix - Page 7 - JeepForum.com
 2Likes
post #91 of 108 Old 11-13-2011, 02:27 PM
rwfisheriv
Thanks for the write-up. I spent a pleasant afternoon drilling and spraying...my plan is to keep spraying until something breaks loose....
rwfisheriv is offline
post #92 of 108 Old 12-11-2011, 05:19 PM
jerresredyj
I'm replacing a 3" BL with a Daystar 1". With all the bushings in, the front bushing has a 1/2" gap at the top. The old 3" bushing are all the same height but Daystar front bushing is a 1/2" shorter than the others. Am I missing something?
jerresredyj is offline
post #93 of 108 Old 01-07-2012, 05:11 PM
yj381
Finished replacing my stock body mounts with a prothane 1" body lift. Didn't have any problem with any bolts except the back two. Had to use my cutoff and peel the metal back like a can opener. I loosened my fan shroud per the instructions, but I checked after I lifted it, and the fan shroud didn't have to be moved, so I bolted it back up.
The only problem I am having is my jeep will not go in 2nd gear and wants to jump out of 4th. I read before that this was because the angles had changed but I am having trouble finding the thread now. I currently have a 2.5 inch skyjacker lift and a lowered transfer case. I'm thinking that I might need to raise my transfer case back up now, but the jeep rides much better with it lowered. I would think about a SYE but I would have to redo that if I switch axles unless I am mistaken, so I would like to hold off until I install a larger rear axle.
Anybody have any thoughts about the best way to regain 2nd?
1995 yj, 2.5l, 2 1/2 skyjacker lift, 1" shackle lift, 1" prothane body lift, 33 x 10.50 bfg ko, raptor lined tub, original owner
yj381 is offline
post #94 of 108 Old 01-07-2012, 07:15 PM
yj381
Here is thread I was looking for, I will post how it turns out
http://www.jeepforum.com/forum/f12/s...y-lift-790489/
yj381 is offline
post #95 of 108 Old 04-03-2012, 07:54 PM
grivera
Originally Posted by Que89YJ View Post
I thought I would try something new to get past cutting the hole for the captive nut. I got 1 out and I will see if I need to use it on the others. I drilled 1/4" away from the bolt through the nut pocket. I left the drill bit in to stop the captive nut from turning and racheted the bolt out. It might save grief and a few large holes in the floor.
Daryl, did this work for all locations, or did you just do the one?
grivera is offline
post #96 of 108 Old 04-04-2012, 07:29 AM
Que89YJ
I just did the one. I did end up cutting the floor on 2 of them and I have 1 nut pocket in the rear I have yet to deal with.
Que89YJ is offline
post #97 of 108 Old 04-05-2012, 06:38 AM
grivera
I bought a set of canyon wheels with 31x10.5" mud terrains, not realizing that the stock suspension will not clear the tires. Now I'm getting ready to install a Prothane 1" body lift and have sprayed the bolts with PB Blaster (via drilled holes) for the last 6 days. I'm not looking forward trying the first bolt...
grivera is offline
post #98 of 108 Old 04-05-2012, 07:17 AM
Que89YJ
Heat is your friend. If you know anyone with a torch call them! After....I did the bolts I swore I would never deal with it again without one and I bought one the next week.
Que89YJ is offline
post #99 of 108 Old 04-06-2012, 08:52 AM
grivera
Yesterday afternoon, I attempted to loosen some of them. On the p-side, the bolt broke on the one behind the front seat, the others came out ok. On the d-side, the rear bumper and the one behind driver's seat broke; the others came out. I haven't attempted the ones near the gas tank on either side yet...will try today and report back.
UPDATE: The ones by the gas tank came out with little effort. I cut a flap on each side of the floor to get the two caged nuts behind the front seats out. I also cut a flap behind the d-side rear tire to get that caged nut out.
grivera is offline
post #100 of 108 Old 04-07-2012, 10:00 PM
grivera
Originally Posted by hdfxrs91 View Post
One thing I experienced... there's a lip on the bottom front of the grille that sticks out forwards. Covering that is a piece of metal supporting the brake lines. All this is hidden under the plastic Jeep cover behind the bumper and in front of the grille. That lip hits up against the metal when the body is lifted. A simple cut-out of the metal where the lip extends will prevent the plate from bowing upwards.
I'm not sure if my '95 is the same, but the grill has metal piece that the body mount bolts to (is this the lip you're referring to?). This piece is heavy gauge
- it sticks out and draws the piece of metal supporting tbrake lines upward. Even without the protective piece in place, the "Jeep" labled plastic cover bows up in the center.
grivera is offline
post #101 of 108 Old 06-09-2013, 08:33 AM
V8-YJ
thanks so much for this thread! I have all my bolts soaking right now, this is so helpful with all the pics
V8-YJ is offline
post #102 of 108 Old 09-17-2015, 02:36 PM
beinnvorlich
Frame bolt sizes.
does anyone know the bolt sizes for the two rearmost mounts. I managed to get the first 9 bolts out but snapped the back two. I ended up drilling out the spot welds on the rear box channel, cutting a section of the back of the channel and folding the metal up and out of the way to get access to the square captive nut. The nuts were loose and just litfted out. I removed the stub of bolts, welded the square nut back in place, folded the metal back down and welded it all back up. Not sure if this is the best method but it worked for me. Now I just need two replacement bolts but what size?
beinnvorlich is offline
post #103 of 108 Old 06-18-2016, 07:22 PM
DirectMatrix
This thread saved my bacon! I've been dreading doing this. As a matter of fact, I think I bought the replacement prothane kit last October!
Snapped the two most rear bolts. Front mount was easy. Only had the drill spray holes for the two under the cargo area and the passenger side near the seat bracket. Whole job still took 8 hours. The two rear were the biggest pain as I needed to get the capture nuts out to drill the broken stud. I went through the side box frame under the mud flap panel. Replaced all the hardware with grade 8, 1/2" x 3.5" #13 bolts. Made my own sleeves out of some stock tubing I found at home depot. Cut them to 2" lengths.
Overall, not a bad project.
~DM
bruinjeeper likes this.
DirectMatrix is online now
post #104 of 108 Old 06-20-2016, 07:12 AM
Que89YJ
~DM
I started loading the nut pockets with grease now. Never want to do that again.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #105 of 108 Old 06-20-2016, 07:56 AM
DirectMatrix
That's an excellent suggestion Que. I'm gonna do just that. Thank!
~DM
YJ Body mount locations mark12010 YJ Wrangler Technical Forum 6 10-12-2016 06:55 AM
Broken Body Mount bolt ChiroSean YJ Wrangler Technical Forum 15 11-08-2010 09:52 AM
TJ body mount locations (pictures?) rikkards TJ Wrangler Technical Forum 3 06-15-2009 03:55 AM
11 Body Mount Locations BRad704 YJ Wrangler Technical Forum 4 01-05-2006 04:00 PM
body mount bolt ?? superman613 TJ Wrangler Technical Forum 2 02-14-2005 10:16 AM
