Body Mount Bolt Locations (For BL) - Detailed Write-Up W/ Pix - Page 6 - JeepForum.com
 2Likes
post #76 of 108 Old 04-14-2011, 10:46 PM
RJMICP
Originally Posted by pointech View Post
I figured this out - there were the remains of a washer rusted to the body. Once I took a better look I realized there was something I needed to pry off.
New question: Just went for my test drive and the steering has more resistance. It also doesn't recenter itself without help. Maybe my steering shaft is unhappy? I looked at it briefly and it is rusty but otherwise looked OK. I sprayed it with some MPL at the joints. Is there something else steering related that I might need to check after this install? Anything in the steering column?
I had the same exact issue on the last YJ that I had put a 1" BL on... it was completely stock... make sure the telescoping shaft bolt is loosened... now the other thing that I found with mine- your resistance in your steering might be because of the black(or tan) plastic housing inside your car nearest to your steering wheel... when you lift it it does pull at it a little and increase the friction... what I did... took the steering wheel off, then the black housing... took my angle grinder and took about 1/8" off the plastic... re-installed it, and the wheel, and the steering was perfect again...
RJMICP is offline
post #77 of 108 Old 04-14-2011, 10:49 PM
RJMICP
Originally Posted by dwar View Post
I purchased my 92 YJ, 4.0L w/auto and it came with a 3" BL. I would like to replace the 3" BL with a 1" BL, but I don't know if there is anything else I need replace because of the BL height (ie. radiator mount, tranny, etc..) Thanks!
you sure you aren't my twin?? I just did the SAME exact thing!! bought a 92 YJ 4.0 that had a 3" BL on it... after reading all the reviews on here, I bought a 1" Daystar and just finished installing it... other than the fact that only 3 of the body bolts came out cleanly, and having to hack the Heep apart to get to the broken nuts, it's now installed and looks MUCH better!!! you really shouldn't have to worry about much else... keep an eye on the fuel lines before lowering it on the new mounts... make sure you loosen the bolt of the telescoping steering shaft... you MIGHT have to relocate the fan shroud, but surprisingly enough, mine wasn't an issue... you'll be much happier with the 1" BL
RJMICP is offline
post #78 of 108 Old 05-02-2011, 06:47 AM
cbl600r
5 of 11 bolts snapped in half. Including the front one. Looks like I might have to drill that one out. As far as the others go, guess I will try to knock the captive nut loose after i drill some 2" holes in the tub.
cbl600r is offline
post #79 of 108 Old 05-04-2011, 06:58 AM
cbl600r
Has anyone snapped the bolt on the front one? How do I fix that one?
cbl600r is offline
post #80 of 108 Old 05-04-2011, 10:36 AM
ckjeep
if you are talking about the bolt under the grille the easiest way is to pull the grille off the jeep. not fun but it is what it is. i had to use a torch to heat the bolt and was able to get the bolt out.
ckjeep is offline
post #81 of 108 Old 05-04-2011, 11:02 AM
tdewit
Originally Posted by NHfireYJ View Post
You'll be there forever, hacking and drilling...using a hole saw or a cut off wheel in a 4" grinder and you'll have at the captive nuts in no time, probably less than 30 minutes. Takes nothing to tack (or even rivit) small filler pieces back in to the floor.
After you rhinoline the tub, you'll never know it was there..( or cover it back up with the carpet)
I totally agree with NHfireYJ. Only difference, when I cut out the 2 1/2" holes with a hole saw, I kept the "plugs". Once done, I put a layer of fiberglass down, put the metal caps back on, another layer of fiberglass, a little bit of sanding once dried, and you'll never see it again.
tdewit is offline
post #82 of 108 Old 05-04-2011, 11:03 AM
tdewit
A+ on that. Just did exacly what ckjeep said last night and it worked like a charm.
tdewit is offline
post #83 of 108 Old 05-04-2011, 11:51 PM
cbl600r
I don't have anything to grab the bolt by now that I have snapped it in half. There is not enough to grab the bolt by above the nut...
cbl600r is offline
post #84 of 108 Old 05-07-2011, 08:35 PM
cbl600r
Ok made some good progress today. I had to do some cutting. Then used an air hammer to chisel the captive nuts out. Also was able the pull the bolt and nut out of the front without removing the grill.
cbl600r is offline
post #85 of 108 Old 05-22-2011, 05:40 PM
cbl600r
Well almost had it all installed today. Until I set the the second side on the new lefts and found that the body had shifted. The body sits about 3/8" off toward the front. Tried to pull it back with a come along. Has it pulling on the roll bar. It just pulled the frame and all with it. Not sure what I am going to do..
cbl600r is offline
post #86 of 108 Old 05-22-2011, 05:44 PM
NHfireLJ
NHfireLJ's Avatar
what is the other end of the come along attached to?
you need to go from the frame to the tub...
Is the other side still loose? If so you should be able to do that with a large drift pin or philips head driver, while someone else starts the bolts...
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #87 of 108 Old 05-22-2011, 06:01 PM
cbl600r
Yes the other side is on the lifts and loosely tightened. Have tgh front on too
Don't quite understand. where do I attach the come along? I am sure I could find a spot on the frame but where on the body/tub?
cbl600r is offline
post #88 of 108 Old 05-22-2011, 06:43 PM
NHfireLJ
NHfireLJ's Avatar
guessing you have to go back with the tub? If so then hook to the rear axle or frame and make a loop with a strap over the front fender or fender brace...
For 3/8 inch you shouldn't have to put to much pressure that you'll do any damage...
You may be getting shift from the jack too..
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #89 of 108 Old 05-23-2011, 07:28 AM
cbl600r
Thanks for the tip. It worked! So glad the BL is almost done. What a royal PITA!
cbl600r is offline
post #90 of 108 Old 05-25-2011, 09:28 PM
dwar
RJMICP, thanks for the info. The steering was my main concern.
1992 4.0L YJ, 2003 Harley Road King Classic, 2002 F350 with 60hp/120hp chip, 4" exhaust, AFE intake, pillar gauges.
dwar is offline
YJ Body mount locations mark12010 YJ Wrangler Technical Forum 6 10-12-2016 06:55 AM
Broken Body Mount bolt ChiroSean YJ Wrangler Technical Forum 15 11-08-2010 09:52 AM
TJ body mount locations (pictures?) rikkards TJ Wrangler Technical Forum 3 06-15-2009 03:55 AM
11 Body Mount Locations BRad704 YJ Wrangler Technical Forum 4 01-05-2006 04:00 PM
body mount bolt ?? superman613 TJ Wrangler Technical Forum 2 02-14-2005 10:16 AM
