Body Mount Bolt Locations (For BL) - Detailed Write-Up W/ Pix - Page 3 - JeepForum.com
 2Likes
post #31 of 108 Old 10-23-2009, 09:58 AM
Why J?
Why J?'s Avatar
I have found that if a captive nut spins sometimes you can drill a small hole through the sheet metal and through the "nut". You can then insert a small metal rod, I use either a screw or a drill bit.
Giving you the ability to hold the nut while you remove the bolt. Once the bolt is removed I usually run a self tapping screw through the hole to secure the captive nut.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #32 of 108 Old 12-30-2009, 03:26 AM
cj3a
my 95 has a 3 inch body lift that is breaking through th body, im going to have to do some welding to fix. got the jeep for 2 grand rust free, but i wasnt expecting the body mounts broken. this is what you you get buying before seeing.
cj3a is offline
post #33 of 108 Old 01-05-2010, 03:38 PM
parkerm26
tryed starting my lift the other day without looking at this thread
didnt turn out well. first mount SNNAAAP... luckily its the one behind the front tire on the passenger side so i can get a new nut and washer in there.-correct me if im wrong.
otherwise im gonna bite the bullet and start drilling the rest. gotta pick up a new can of pb first. yj owners know you should always have an extra in stock
Thanks for the write up. ill post back with results
93YJ 350-465-205, D60 and 14 Bolt, 40's http://www.jeepforum.com/forum/f22/yj-rustoration-1327569/
parkerm26 is offline
post #34 of 108 Old 01-05-2010, 03:41 PM
parkerm26
actually question- i snapped the bolt off with about an inch on it. but for some reason the nut and rest of the bolt will not come out the top. it will wiggle and twist a bit but wont come out. any ideas?!
post #35 of 108 Old 01-05-2010, 03:51 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
That's because it's not a "nut" at all. It is a threaded plate held captive by a sheetmetal cage.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #36 of 108 Old 01-05-2010, 04:52 PM
SCBeachbum
Great thread guys. I started on my bl install over the weekend, tried two mounts and both spun the captive nuts. I was actually going to abandon the whole bl install until I read this thread. Thanks for the tips.
I DO DIRT.......FOR REAL!!!
1987 YJ 4.2 0n 33's SOLD
1997 TJ 2.5 On 33's
1998 TJ 4.0 On 35's
SCBeachbum is offline
post #37 of 108 Old 01-06-2010, 09:01 AM
parkerm26
max any advice on getting it out? otherwise its hack and weld in a few months wen i have the availability of a welder
any better suggestions? should i start a new thread for ideas or is that my only option? HELP WANTED
post #38 of 108 Old 01-06-2010, 11:57 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
You can use a hole saw & then dig it out from the top, like in the pics in post 22.
Max
Mean Max is offline
post #39 of 108 Old 01-07-2010, 01:31 PM
parkerm26
so i guess that means i would be going through the front floor board?
post #40 of 108 Old 01-28-2010, 04:38 PM
JOExFROMxNY
Originally Posted by Rustbucket83 View Post
Ok so I gave up on reusing the body mount points and cut them with a Torch,
after spending 3 hrs trying to get them loose I broke three, spun three more and got
a couple to come out.
I went to what I did with My old Cj and Welded blocks that I made as lift mounts.
3" blocks netted me 2" BL with my 1 1/2" shackles and 1" flare trim.
Essentially a Poor man's 4.5" lift for 33's.
No rubbing and nothing bad with the ride happened instead I noticed it a Bit Tighter.
If anyone is considering doing a body lift this way I caution you as it IS permanent for the most part.
I don't plan on changing my stuff anytime soon so it worked
well for me.
Thought I would add to this thread in case anyone is already where I was, Stuck.
do you have any photos/specs of the blocks you made, or photos of them installed?
JOExFROMxNY is offline
post #41 of 108 Old 01-28-2010, 07:30 PM
EZ95YJ
I have seen mention of a 1" BL together with a replacement mount. So I thought I what a concept. The trouble is I can't find them. does anyone know who makes these? Thanks!
EZ95YJ is offline
post #42 of 108 Old 01-28-2010, 07:40 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Daystar.
KJ04505BK - Comfort Ride 1 Inch Body Lift For 1987-95 Jeep Wrangler YJ | Discount Jeep Parts
Max
Mean Max is offline
post #43 of 108 Old 01-28-2010, 07:41 PM
cj3a
Prothane, and Daystar 4wd.com
cj3a is offline
post #44 of 108 Old 01-29-2010, 08:46 AM
JOExFROMxNY
post #45 of 108 Old 01-29-2010, 09:53 AM
NHfireLJ
NHfireLJ's Avatar
I just used this kit.. recommend it...
also did the "thru the floor board" access to get to the broken nuts/bolts.
replaced mine with flat bar and welded nuts...
Also most of my frame mounts had rotted thru the diameter of the bodymount, so I had to fill them with plate to create a new landing point for the body mounts...
If you use a 2 1/2" hole saw you can access the rear captive nuts, (go thru the wall, not the bottom) remove them and replace with new..
NHfireLJ is offline
YJ Body mount locations mark12010 YJ Wrangler Technical Forum 6 10-12-2016 07:55 AM
Broken Body Mount bolt ChiroSean YJ Wrangler Technical Forum 15 11-08-2010 10:52 AM
TJ body mount locations (pictures?) rikkards TJ Wrangler Technical Forum 3 06-15-2009 04:55 AM
11 Body Mount Locations BRad704 YJ Wrangler Technical Forum 4 01-05-2006 05:00 PM
body mount bolt ?? superman613 TJ Wrangler Technical Forum 2 02-14-2005 11:16 AM
