Body Mount Bolt Locations (For BL) - Detailed Write-Up W/ Pix - JeepForum.com
 2Likes
post #1 of 108 Old 02-27-2009, 04:24 PM Thread Starter
CheapSunglasses
2007 XK Commander
OK....I've seen many threads started about body lifts, body mount locations, the number of body mount bolts, how to remove them, etc., so I thought I'd start a detailed thread after I located all of mine.
This thread was inspired by a post in an earlier thread about stuck and rusted body mount bolts where a poster (sorry, can't remember who) suggested to drill a small hole near each bolt in order to spray it liberally with PB Blaster.
All of the pix are from the pass side of mi rig, which is an '89. It should be the same for most. I will try to describe the locations as accurately as I can, but feel free to reply if I didn't make it clear enough.
There are a total of 11 bolts and I'll start at the front and work my way to the back.
The first one is located under the front bumper and dead center below the radiator. Pretty simple.
The second one is located very near the rear leaf spring mount of the front spring, and can be sprayed without drilling the floor of the tub. Just get under there and you'll see what I mean. Repeat for driver side.
The third one is a bit more tricky. You need to drill a small hole (1/4" or 3/8" is fine) right in front of the seat bracket that is closest to the rocker (not the bracket nearest the trans hump). This will allow you to spray the PB right onto the offending bolt/nut plate. If you get it right, you'll see PB dripping from underneath. Repeat for driver side.
The fourth one is located behind the front seat, near the rollbar and front seatbelt mounts, directly under a little bump in the floor (about the size of half a golf ball). When you drill this hole, you will hit the top of the bolt end which is about a 1/4" below the bump. Repeat for driver side.
The fifth one is located inside the tub, under the rear seat. Fold the seat out of the way and follow the raised support ridge nearest the wheel well, about 18"-20" in from the back door jamb (kinda near the rear seat belt mount) and you'll see a little extension off the ridge. The bolt is located directly under that extension. With this one, I found that the bolt end was right smack against the metal of the tub, so I drilled the hole a little off center and it worked fine. Repeat for driver side.
Last but not least is the one located at the very rear corner of the tub. For this one, you need to pull the plastic mud guard out of the way (as if you were getting to the wiring for the tank sending unit), and drill the hole in the face of the box that is there for tub support (I believe), and spray in at the side of the bolt as opposed to from the top. See the little silver speck by the arrow? That's the hole. Not the greatest pic.
That's about it. It's a pretty simple job that took me less than an hour. All the sheet metal is not real heavy gauge and drills with ease. I'm gonna spray my bolts a couple of times a day for a week before I even attempt to remove them.
I hope this thread help. I've gotten tons of great info on this board and just wanted to give a little back.
Dkrom likes this.
"The Bannana Channell, Programming With Appeal"....Stay Tuned For a Bunch More!
CheapSunglasses is offline
post #2 of 108 Old 02-27-2009, 04:45 PM
ZeroGravity
I beleive you have to remove the gas tank for the bolts mounted under the bed.
ZeroGravity is offline
post #3 of 108 Old 02-27-2009, 05:08 PM Thread Starter
CheapSunglasses
2007 XK Commander
Not really....If you have a swivel and an extension, you should be able to get to them, but I'll post back next weekend (weather permitting) when I do the BL.
post #4 of 108 Old 02-27-2009, 05:12 PM
ZeroGravity
Ok. It was the first thing that popped into my head.
I'm glad to see the thread.
post #5 of 108 Old 02-27-2009, 05:17 PM
RobsYJeep
sweet!! I've been thinking of starting a thread like this...
thank you CHEAPSUNGLASSES!!!!
My JEEP is just a project until it becomes an obsession...
RobsYJeep is offline
post #6 of 108 Old 02-27-2009, 05:22 PM
Burnerman
Burnerman's Avatar
You can get to them with just a 4" extension. Nothing has to be removed to get to the heads of the bolts.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #7 of 108 Old 02-27-2009, 05:34 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Excellent write-up, and I can't wait to get home from work to view the pics (they're blocked for me here at work) that you took!
I think you were referring to my post here.
http://www.jeepforum.com/forum/f12/body-lift-carnage-how-avoid-693392/
Again, excellent job!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #8 of 108 Old 02-27-2009, 06:51 PM Thread Starter
CheapSunglasses
2007 XK Commander
http://www.jeepforum.com/forum/showthread.php?t=693392
Max
Yup....That's the one....And coincidentally, we both have red rigs.
post #9 of 108 Old 02-28-2009, 10:50 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
I just saw the pics, they look great! Nice job with great info!
I noticed that! I pulled up next to a much newer & cleaner red TJ in traffic the other day, we both had our windows unzipped and the girl driving it gave me the Jeep wave. I yelled out to her, "Love the color!" and she yelled back, "Same here, there's just not enough red Jeeps around!"
Max
Mean Max is offline
post #10 of 108 Old 02-28-2009, 01:49 PM Thread Starter
CheapSunglasses
2007 XK Commander
Max
Yeah, but was she hot?
post #11 of 108 Old 02-28-2009, 02:11 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I'm (happily!) married to another JF member, so I will neither confirm nor deny and just say "I didn't notice."
Max
Mean Max is offline
post #12 of 108 Old 02-28-2009, 07:37 PM Thread Starter
CheapSunglasses
2007 XK Commander
post #13 of 108 Old 03-16-2009, 06:08 PM Thread Starter
CheapSunglasses
2007 XK Commander
OK....After a couple of weeks spraying PB Blaster on all the mount bolts, I finally installed the 1" BL....All of the bolts came out with little effort except the two rear ones at the tub corners (see last pic, post #1)....They snapped off clean inside the rear box that I think helps support the tub .
I took a 2-1/8" hole saw I use for cutting locksets into metal entry doors, and cut a hole in the tin support box expecting to have to chisel, grind, or torch the captive nut (plate) out, but to my surprise (and extreme pleasure) It was only held in place by two metal tabs which I simply bent out of the way and removed the plate and rest of the snapped bolt.
I then just put a normal nut and washer in place and thru bolted both sides....I'm gonna go to Homey D tomorrow and buy a couple of galvanized plates used for deck building and screw them over the hole with a couple of self tappers.
I'll post pix after I install my Brandon Booms.
post #14 of 108 Old 03-24-2009, 07:35 PM
nickstix
Im looking into putting in a 1" body lift on my 93 YJ. Is there anything besides the actual body mounts that has to be raised or lowered? also are there any special tools you need to lift the tub up off the frame?
nickstix is offline
post #15 of 108 Old 03-24-2009, 08:23 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I loosen all 11 body bolts first, then remove the front one under the radiator and the 5 along one side or the other, leaving the 5 on the other side still threaded in, but loose. This keeps the tub from shifting out of place.
I usually take the gas filler neck plastic off & then reinstall after the lift to avoid cracking the plastic, the hoses should have enough play in them.
I use a board under the rocker panel to distribute the weight so it doesn't distort the metal from having all the weight in one place.
I use a 1" motor mount lift to keep the fan in line with the radiator shroud, but you don't have to. You can relocate the shroud down 1" instead.
Max
Mean Max is offline
YJ Body mount locations mark12010 YJ Wrangler Technical Forum 6 10-12-2016 06:55 AM
Broken Body Mount bolt ChiroSean YJ Wrangler Technical Forum 15 11-08-2010 09:52 AM
TJ body mount locations (pictures?) rikkards TJ Wrangler Technical Forum 3 06-15-2009 03:55 AM
11 Body Mount Locations BRad704 YJ Wrangler Technical Forum 4 01-05-2006 04:00 PM
body mount bolt ?? superman613 TJ Wrangler Technical Forum 2 02-14-2005 10:16 AM
