Body Lifts - JeepForum.com
post #1 of 5 Old 03-06-2002, 09:17 AM Thread Starter
Black Dragon
Body Lifts
I was just wondering If I could install a body lift on my 89 YJ myself and do I have to do any thing with stuff like wireing and the steering column,
Thanks
Black Dragon is offline
post #2 of 5 Old 03-06-2002, 09:26 AM
RodeoRob
RodeoRob's Avatar
how much body? 1" you could install without doing anything other than inserting the pucks.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 5 Old 03-06-2002, 09:51 AM Thread Starter
Black Dragon
I was thinking about a 2inch body lift
post #4 of 5 Old 03-06-2002, 09:58 AM
SBall
Yes, this is a fairly simple procedure. However, I would recommend recruiting a friend or two just to make the job a little bit less scary-like when you are actually jacking up the body of your jeep on one side and it is tilted off of the frame. Two or more people just helps the safety factor for yourself and your jeep. Plus you can drink beer at the same time-haha. You should not have any wiring problems. With 2" you will need to install the radiator and exhaust drop brackets-easy, but the radiator is a PITA. The steering column is easy enough to deal with. You simply loosen a bolt before lifting and the shaft will slide out and then you tighten it back up when the lift is complete. This is definitely a do it yourselfer.
92 YJ 4.0L, 35" Goodyear MTR's, Rough Country Suspension
SBall is offline
post #5 of 5 Old 03-06-2002, 09:10 PM
BzJeep
BzJeep's Avatar
If I get a 4" Lift and 3" Body Lift, what do I need to do with that kind of stuff? Like wiring and getting new parts because they ar to short... Catch me?
Thanks
2008 Metropolitan Gray Mazda3S Sport
2001 Steel Blue Grand Limited *SOLD*
1993 Forest Green Wrangler *SOLD*
Green Jeep Club Member #16
BzJeep is offline
What is the best.... (suspension lifts and body lifts) RjAndJeep TJ Wrangler Technical Forum 24 06-03-2009 09:33 PM
A run down on suspension lifts.body lifts.spacers mightydog78 TJ Wrangler Technical Forum 5 02-28-2009 12:21 AM
Body lifts/Suspension lifts OffRoadin'Lover TJ Wrangler Technical Forum 4 11-18-2006 02:57 PM
Questions on lifts and body lifts WrangBlake TJ Wrangler Technical Forum 3 10-06-2006 02:46 PM
BODY LIFTS........BODY MOUNTS ONEDIRTYTJ TJ Wrangler Technical Forum 4 07-17-2001 04:01 PM
