Body Lift and Radiator Shroud Relocation - JeepForum.com
post #1 of 7 Old 02-22-2012, 09:43 PM Thread Starter
Supertrey
I just installed the M.O.R.E. 1" body lift on my YJ (4.0L). The instructions say to mark new holes 1" lower on the radiator and remount the shroud in the new holes. I researched this procedure on the forum and the explanations are all the same: redrill and move down.
Here is the problem, my radiator shroud sits barely above the lower radiator hose in the stock position. It is impossible to lower it because of the hose.
I have not seen anything in the threads I read, does anyone have a suggestion? I was going wheeling this weekend so I need some help!! Thanks!!
1992 YJ, 4.0L with 1" MML and stock drive train with AX15 and 4.10 gears, 3.5" Fabtech leaf springs, 1" BL, 31" Buckshot XMTs, Softtopper, Ford Ranger Bench seat, Metal Cloak Overlines and Genright rear flares, 1" M.O.R.E. Body lift, Lots of stuff in the works!
Supertrey is offline
post #2 of 7 Old 02-22-2012, 09:50 PM
jeepnbrett
I made some simple new L brackets that are an inch longer for the top radiator mounts. For the lower mounts I redrilled the mounting holes in the radiator an inch higher up. This dropped the entire radiator down an inch.
Brett
4.0, AT, 3.5 Fabtech, 1" SRS, 1" BL, 35x13.50x15 Toyo MT's, HP30, TJ shafts, Lockrite, 8.8, Power Trax No Slip, 4.11's, Warn bumpers, W8274, SYE, and a bunch of other stuff....
jeepnbrett is offline
post #3 of 7 Old 02-23-2012, 04:20 AM
WakeDoctor
^^^^^ This
You will have to move the whole radiator not just the shroud.
WakeDoctor is offline
post #4 of 7 Old 02-23-2012, 07:41 AM
Que89YJ
Do the Tarus fan mod when you do the lift. It's when I did mine. I got rid of the shroud all together.
Que89YJ is offline
post #5 of 7 Old 02-23-2012, 07:48 AM
JCJeep97
You might want to just do a MML along with the BL instead of screwing with the radiator. . . . I have a TJ though, don't know if this applies to YJ's.
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline
post #6 of 7 Old 02-23-2012, 08:40 AM Thread Starter
Supertrey
I ordered a brown dog industries motor mount lift but I had a wheeling trip planned for Sunday and I don't know if motor mounts will be here in time. That is why I was going to try to do the radiator shroud in the meantime and discovered that it would not lower. I don't want to miss my trip Sunday because of this silly radiator shroud if the motor mounts don't come in.
post #7 of 7 Old 02-23-2012, 09:09 AM
brentd711
I notched my shroud for the lower hose and dropped it an inch and a half
brentd711 is offline
Body Lift - Fan Shroud Relocation Issue TJtexasTJ TJ Wrangler Technical Forum 4 10-14-2009 06:16 PM
Fan Shroud _ BODY LIFT _ HELP Doc_Vegas TJ Wrangler Technical Forum 14 04-12-2009 11:17 AM
radiator relocation with body lift? brinoff YJ Wrangler Technical Forum 4 03-08-2009 08:08 PM
Motor Mount Lift + Body Lift = Radiator Shroud Placement? tommanns YJ Wrangler Technical Forum 6 01-26-2009 08:04 PM
1" body lift/radiator fan shroud jgillespie YJ Wrangler Technical Forum 9 06-21-2008 12:35 PM
