Body LIft Question - JeepForum.com
post #1 of 5 Old 04-19-2004, 03:39 PM Thread Starter
Dan R
Body LIft Question
Do the body lift kits come with new (longer) bolts? If so, how do you get at them to put them in? I know the stock ones aren't long enough to accomodate another 1-2", so how do you bolt the body to the frame?
Thanks
Dan R is offline
post #2 of 5 Old 04-19-2004, 04:50 PM
Fastbeeatch
Thanks
The bolts bolt from the underside up the frame as a nut or something welded to it, whatever kit you get will have the longer bolts to accomodate the lift pucks.
95 4L Auto D300 TC
103" Wheelbase
D60 Front 14 Bolt Rear 4.10 Gears
H1 Wheels 36" GoodYear OZ Tires
Fastbeeatch is offline
post #3 of 5 Old 04-19-2004, 05:23 PM Thread Starter
Dan R
I guess I don't really understand how it attaches to the frame then. I thought that the bolt came down through the body and frame mount and there was a nut on the bottom? I looked at the rear two and it doesn't look like there is any way of getting the bolt out without cutting a big hole in the body?
Dan R is offline
post #4 of 5 Old 04-19-2004, 05:52 PM
Fastbeeatch
the bolts don't come from the top. If you look inside youre jeep there is no signs of bolts. Look under the jeep @ the spacers and you will see a bolt, i'm not sure if it bolts to a nut welded to the frame or what maybee someone else can answer that. Actualy search for a body lift install and look for the one written up by Moxley he explains the whole thing pretty good.
95 4L Auto D300 TC
103" Wheelbase
post #5 of 5 Old 04-19-2004, 11:28 PM
blackw
Just put a Daystar body lift on Sunday. The bolts go up from the bottom through the bracket (which is attached to the frame) and then into the body. If you look inside your tub you will see a domed out area where the bolt is and where you would think a nut would be but there is no nut. Inside the domed area is a plate for the bolt to screw into. You just tighten from below and the bolt will screw into the plate. I am in the process of doing a write up and will have pics of this soon, i'll post them here when I get it done.
Green 95 YJ 2.5L
3.5" Superlift, 1" Daystar BL
Flowmaster 40 series exhaust, hi-flo cat
BFG Mud Terrain 33X12.50R15's
My Jeep page: http://www.math.ucsb.edu/~blackw/jeep.htm
blackw is offline
body lift or suspension lift, no this isnt a stupid question!! lumpster TJ Wrangler Technical Forum 5 05-11-2009 09:19 PM
Another Body Lift and Spring Lift question KnightofMopar YJ Wrangler Technical Forum 11 03-10-2009 11:48 AM
Body lift question need help jdub92179 TJ Wrangler Technical Forum 14 12-07-2007 01:20 PM
M.O.R.E. Body Lift Question timekpr TJ Wrangler Technical Forum 4 06-05-2005 09:33 PM
Body Lift Question jeepnguns TJ Wrangler Technical Forum 6 10-18-2004 08:08 AM
