Body lift opinions.. - JeepForum.com
post #1 of 29 Old 09-08-2012, 04:49 AM Thread Starter
bcusstc
Currently she has what looks like an 2.5 or 3 inch suspension lift that was installed before i bought her. She just isnt sitting where i want her to. Just curious on everyone's thoughts on a inch and half body lift? and if there are any issues i should watch for afterwards?
Do the blocks go on over top of the body mounts or do the body mounts come off all together?
bcusstc is offline
post #2 of 29 Old 09-08-2012, 06:22 AM
YJPete
It's good for getting a little extra tire clearance but don't go overboard, as it's no replacement for a suspension lift. Watch out for your shifters hitting the body before they engage once it's in. Novak makes a shift linkage that fixes that, so if it becomes a problem I'd look there.
Black 95 YJ
2.5" on the suspension, 1" on the shackles, 2" on the body, 4.88 Superior Gears, 35" Goodyear MT/R with Kevlar, MSD-6 Offroad ignition box, Flowmaster Exhaust, Warn 9.5Ti Winch, Detroit Tru-Trac Front, Detroit Locker Back
YJPete is offline
post #3 of 29 Old 09-08-2012, 06:41 AM
MLJeeper
MLJeeper's Avatar
Try to keep body lifts 2" or below,use quality materials and proper installation and you wont have any trouble. Assuming it meets these criteria, I wouldnt worry about it . Mines been on its side numerous times with no probs. You can always remove it later if it doesnt fit in with your plans. Blocks go over the mounts.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #4 of 29 Old 09-08-2012, 10:22 AM
jeep108
Depends on which lift you buy, some replace the entire mount some are "pucks" that sit atop the oem mount. As stated dont go over board, personally 1.5 would be my max. Dont forget to take the bolts out of the fan shroud & the support bar between the bumper and the grill (if you still have it) before you start lifting on the body
Find the"YJ of the month" contest in the stickies and participate!
Eph 6:13 -Therefore put on the full armor of God, so that when the day of evil comes, you may be able to stand your ground,
Originally Posted by Opihi59 View Post
Welcome to the forum.
If you are a mechanical neophyte and have to repetitively intone the mantra of "lefty loosey," are a mouth breather and only own a hammer, it will be more of a challenge.
jeep108 is offline
post #5 of 29 Old 09-08-2012, 11:04 AM
czjeeper
I put a Prothane 1" body lift on.
It's a fantastic kit that replaces all hardware and does not re-use the body mounts.
I HIGHLY recommend it!
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #6 of 29 Old 09-08-2012, 11:52 AM
brinoff
brinoff's Avatar
Also, keep an eye on the steering shaft. If it does not telescope correctly, it can be difficult to assemble. I couldn't figure out why my tub kept pulling forward on the driver's side while installing my 1" body lift. No one had mentioned the steering shaft
93YJ 4.0 I6, AX-15, NP231 Teraflex SYE, Tom Wood Drive Shaft, G2 D44 ARB, ARB locked 30, T&T customs axle trusses, ProComp 35" Mud Terrain, RE SD 4" Lift, Daystar 1" BL, Harbor Freight 8000 Winch, Swing Away Tire Carrier, and some other stuff.
brinoff is offline
post #7 of 29 Old 09-08-2012, 02:41 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I've got a daystar 1" kit and it's perfect for what I need out of it.
-Little more clearance for tires
-Replaces old body mounts
-Gives tranny and transfer case a little room to run a high clearance skid
-Gives my gas tank room for its high clearance skid
-Leaves a little room to get a pressure washer nozzle inside if I traverse mud
I'm sure there is more but anything over 1" will start to apply a little more stress to the mounts.
Luck Favours The Prepared
Anticanman is offline
post #8 of 29 Old 09-09-2012, 06:01 AM Thread Starter
bcusstc
I don't plan on going over 1.5 inches, I am only looking at the body lift because im not a fan of the short and stout look. i would rather see her sit a little higher and look more proportioned if that makes any sense.
Some of the kits i am looking at include the hardware to extend the shifters and the radiators. but do i need those things if its just a 1 inch body lift?
bcusstc is offline
post #9 of 29 Old 09-09-2012, 06:48 AM
YJPete
I've got 2" and I couldn't get into 4lo at all without adjusting the linkage. The shifter hit the (now taller) body before it got far enough. I imagine with 1" you may not have quite that problem but it'll still probably keep some pressure on it, which I wouldn't want.
Black 95 YJ
YJPete is offline
post #10 of 29 Old 09-09-2012, 09:05 AM
jeep108
Probably not, mine is a 1.25". I had to remove the inner shift boot line so it would stay in 4th and move my radiator shroud to keep the fan from hitting. Within 6 months I installed a 1" motor mount lift which then caused me to move my shroud back down. Other things to watch during installation... Gas tank filler hose (neck?) and front brake lines.
jeep108 is offline
post #11 of 29 Old 09-09-2012, 09:12 AM
ghetdjc320
I would recommend either the daystar 1" or the JKS since the regular pucks tend to move arroyos with time and wheeling.
-DJC
ghetdjc320 is offline
post #12 of 29 Old 09-09-2012, 12:17 PM
jeep108
I've heard of moving mountains but never arroyos jk, ain't auto spell great
jeep108 is offline
post #13 of 29 Old 09-09-2012, 02:46 PM
ghetdjc320
Hehehehe gotta love spell check in Mexico!!
-DJC
post #14 of 29 Old 09-09-2012, 07:43 PM
MLJeeper
MLJeeper's Avatar
5 seconds with a grinder
MLJeeper is offline
post #15 of 29 Old 09-09-2012, 07:51 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It's called using your Man Hands when shifting. It'll eventually go into gear.
Opinions please: Putting on a Body Lift while saving for Suspension lift ZMBJ33P TJ Wrangler Technical Forum 6 12-05-2011 08:49 PM
Body lift...neep opinions please 141 TJ Wrangler Technical Forum 21 06-07-2011 01:06 PM
Body Lift opinions wanted. moonshinefuel YJ Wrangler Technical Forum 33 06-17-2010 10:09 PM
2" body lift opinions Chris @ GATR TJ Wrangler Technical Forum 5 06-12-2007 01:06 PM
Motor mount / Body lift opinions?!?! PeteWranlger TJ Wrangler Technical Forum 1 10-13-2003 10:44 PM
