-   -   Body lift... now can't shift (http://www.jeepforum.com/forum/f12/body-lift-now-cant-shift-1467567/)
95Turtle 01-22-2013 04:11 PM
All poetry aside... Just installed a 1" Daystar body lift to replace my worn out stock body bushings. Now I have a hard time shifting to 2nd, 4th, and Reverse. I cut away part of the floor in this area when I installed the transfer case drop with my suspension lift. I pulled the shifter boots up and the shifter is not hitting the body, but the rubber dust shield thing that goes beneath the shift boot is binding up between shifter and floor when I shift into 2nd, etc. What is the fix here? Can I just remove this piece and put the shift boot back on? Or has anyone tried to cut some material out of it to make shifting easier?
timatoe 01-22-2013 04:54 PM
I don't have that secondary boot on mine. Not saying it's the right thing to do but it certainly worked for mine when it had the 2" BL on it.
Mean Max 01-22-2013 04:55 PM
Pitch that secondary boot in the trash.
Max
crackedcornish 01-22-2013 05:36 PM
get a sye, a cut down XJ front DS, a 1" MML, and a flatter skid to move your tranny/transfer case back up into the trans tunnel ....and gain some ground clearance under your belly :D
95Turtle 01-22-2013 06:02 PM
Thanks, timatoe and Max, I will tear the secondary boot out. Crackedcornish, that is good advice, but probably more than I want to get into. I don't do a lot of harcore wheeling, the Jeep is just a spare vehicle that I like to tinker around with. I have all the ground clearance I need for the time being...
NHfireLJ 01-22-2013 07:38 PM
1404 Attachment(s)
Yeah, it's not unusual to trim the tub at the rear of the shifter tunnel...a 1/2" does it...
dbikers 01-22-2013 08:20 PM
yup....drop the 2nd boot and cut some out some more floor.....take a l'il at a time and you'll get it
Louie4 01-23-2013 04:57 AM
Mine did the same with the t-case drop. After I lost that for an SYE it was fine. A little trimming never hurts though.
95Turtle 01-23-2013 08:01 AM
The secondary boot is what was doing me in... shifter was at least 3/4 inch from hitting the edge of the floor. Got rid of the boot and I'm in good shape now.
Mean Max 01-23-2013 02:46 PM
Great news! Thanks for updating the thread with your results!
Max
The time now is 10:17 AM.
