Body lift... now can't shift - JeepForum.com
post #1 of 10 Old 01-22-2013, 05:11 PM Thread Starter
95Turtle
All poetry aside... Just installed a 1" Daystar body lift to replace my worn out stock body bushings. Now I have a hard time shifting to 2nd, 4th, and Reverse. I cut away part of the floor in this area when I installed the transfer case drop with my suspension lift. I pulled the shifter boots up and the shifter is not hitting the body, but the rubber dust shield thing that goes beneath the shift boot is binding up between shifter and floor when I shift into 2nd, etc. What is the fix here? Can I just remove this piece and put the shift boot back on? Or has anyone tried to cut some material out of it to make shifting easier?
95Turtle is offline
post #2 of 10 Old 01-22-2013, 05:54 PM
timatoe
timatoe's Avatar
I don't have that secondary boot on mine. Not saying it's the right thing to do but it certainly worked for mine when it had the 2" BL on it.
timatoe is online now
post #3 of 10 Old 01-22-2013, 05:55 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Pitch that secondary boot in the trash.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 10 Old 01-22-2013, 06:36 PM
crackedcornish
get a sye, a cut down XJ front DS, a 1" MML, and a flatter skid to move your tranny/transfer case back up into the trans tunnel ....and gain some ground clearance under your belly
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #5 of 10 Old 01-22-2013, 07:02 PM Thread Starter
95Turtle
Thanks, timatoe and Max, I will tear the secondary boot out. Crackedcornish, that is good advice, but probably more than I want to get into. I don't do a lot of harcore wheeling, the Jeep is just a spare vehicle that I like to tinker around with. I have all the ground clearance I need for the time being...
95Turtle is offline
post #6 of 10 Old 01-22-2013, 08:38 PM
NHfireLJ
NHfireLJ's Avatar
Yeah, it's not unusual to trim the tub at the rear of the shifter tunnel...a 1/2" does it...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #7 of 10 Old 01-22-2013, 09:20 PM
dbikers
yup....drop the 2nd boot and cut some out some more floor.....take a l'il at a time and you'll get it
STUPID HURTS.......OUCH!@#$
dbikers is offline
post #8 of 10 Old 01-23-2013, 05:57 AM
Louie4
Mine did the same with the t-case drop. After I lost that for an SYE it was fine. A little trimming never hurts though.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #9 of 10 Old 01-23-2013, 09:01 AM Thread Starter
95Turtle
The secondary boot is what was doing me in... shifter was at least 3/4 inch from hitting the edge of the floor. Got rid of the boot and I'm in good shape now.
95Turtle is offline
post #10 of 10 Old 01-23-2013, 03:46 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Great news! Thanks for updating the thread with your results!
Max
Mean Max is offline
