Quantcast Body lift install tips? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Body lift install tips?
Old 12-20-2005, 01:07 AM   #1
Tomb Raider
MyJKRocks!
I am going to be installing a body lift on my YJ this weekend. Any tips that might make it go a little faster/easier? It's a 95 with minimal rust, so not too concerned with rusty bolts...but anything else I might consider? I put one on an older suburban once...and it went on painlessly. I'm hoping this will be the same.
2007 JK Unlimited Sahara
37" Irok ND's
4" rough country lift
Tomb Raider is offline   Reply With Quote
Old 12-20-2005, 02:09 AM   #2
'88YJ
just make sure you drop your radiator, me and my buddy forgot to do that on his TJ and we lost all the antifreeze and a hose too...don't forget
1988 Jeep Wrangler YJ
2.5 L - 3.5" Fabtech Suspension Lift - 33x12.5" ProComp Mud Terrains wrapped around 15x10" Mickey Thompsons - JVC head unit - VDP six speaker sound bar - 600 watt amp and 10" Kenwood sub - Tuffy stereo console - 2 KC DayLighters on front bumper - summit racing turbo muffler - herculined interior - 48" farm jack mounted on rollbars
'88YJ is offline   Reply With Quote
Old 12-20-2005, 03:40 AM   #3
blevinsbulldog
you don't have to lower it with a 1'' lift , i don't know about the 2'' , but i know you have to with the 3'' lift.
95' RIO GRANDE
2.5 AKA THE SCREAMING HAMSTER
REAR TRACK BAR REMOVED
1 1/4 SHACKLES---3''BL
33X12.50 BFG A/T
[COLOR=Green]GREEN JEEP CLUB MEMBER # 176[/COLOR]
blevinsbulldog is offline   Reply With Quote
Old 12-20-2005, 06:57 AM   #4
rsoffar
id still hit the bolts with some pb blaster just for safe measure and it cant hurt
94 4.0 auto, tj flares, 31x10.5 bfg mt, a to z rockers
"Pc load letter.... what the f#*k does that mean!?" Michael Bolton
[CENTER][URL=www.jeepforum.com]www.lonestarjeepclub.com[/URL][/CENTER]
rsoffar is offline   Reply With Quote
Old 12-20-2005, 07:39 AM   #5
Brown Dog
Vendor
Brown Dog's Avatar
Two inch lift requires radiator drop, or lifted motor mounts (I won't spam you on that one...but we have them).
I've never installed a one inch lift, but I'm surprised to hear that you don't need a radiator drop or mount lift. hmmmmm.
Brown Dog Offroad
http://www.browndogoffroad.com
The Jeep Forum Discount is ON!!
Join our FaceBook group
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% MADE IN AMERICA
OFFROAD-REVIEW of Browndog Superkit
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
3.5" Superlift SL
AA SYE
35" BFG Mud Terrains
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline   Reply With Quote
Old 12-20-2005, 08:45 AM   #6
Tomb Raider
MyJKRocks!
The BL kit came with radiator drop brackets.
Your probably right on the PB Blaster.
Anything else??? This will be my weekend project, this is a daily driver...so don't want to get in the middle and not have what I need. Thanks for the replies....keepem comin!
37" Irok ND's
Old 12-20-2005, 09:00 AM   #7
rsoffar
i am pretty sure even a 1" needs drop brackets or mml
Old 12-20-2005, 09:32 AM   #8
Slapahoe
Registered Jerk
Slapahoe's Avatar
Deffinatly soak those mother every day starting now. You'll be greatful you did when you arent cuting up the inside of the tub to get a a loose nut. I know from experience.
93 YJ 4.0HO
'03 KJ Renegade
Slapahoe is offline   Reply With Quote
Old 12-20-2005, 09:35 AM   #9
Slapahoe
Registered Jerk
Slapahoe's Avatar
Do you have an Auto or no?
you might have to grind away a bit at the floor where your shifters are. Might.
93 YJ 4.0HO
'03 KJ Renegade
Old 12-20-2005, 09:48 AM   #10
SoCoYJ
I guess I was just lucky, I didn't have to drop anything at all. Put them in there and off I went. I did the 1" and yes it came with all the brackets and all hardware but I didn't need it.
I'd hit the bolts with PB like said before. Also do one side at a time. I saved the one in the front for the last side if I remember right. I had air tools when I did mine but it took me no more than 45 minutes, more toward 30. Good luck.
SoCoYJ is offline   Reply With Quote
Old 12-20-2005, 12:54 PM   #11
MNKMcNeilly
I did a 2" BL not too long ago. One thing I ran into was the steering shaft. There is a bolt that you need to loosen on the steering shaft (at the top near that firewall) so that the shaft would extend a little. I barely noticed it moved, but with out the extention I had a clicking in the column. The drop brackets are easy to do and everything else is self expainatory. Oh, and when you find that there are only 9 body mounts...look right in front on your gas tank on each side (you can access them through the wheel well). I had to do a search to find these. Good luck. Make sure you post some pictures when you are finished.
BTW: How are you liking the Baja Claws?
MNKMcNeilly is offline   Reply With Quote
Old 12-20-2005, 03:00 PM   #12
Tomb Raider
MyJKRocks!
Thats what I was looking for! Thanks for all the replies! I'll post up some pics as I do it this weekend.
As for the claws.....actually much better than I anticipated. They ride much quieter than my BFG M/T's did. I venture to say they are even quieter than my 31in Yokohama Geolanders. The ride is obviously a bit more harsh than the 31's previous....but that is to be expected. All in all....worth every penny. Just need to get this darn body lift on so I can wheel a bit!
37" Irok ND's
Old 12-20-2005, 03:44 PM   #13
Brindle19
Location: Pine Grove, PA HERE IN PINE GORVE WE PREGAME LIKE YOU BOYS PARTY
where am i spraying the body mounts bolts up at..???at the bottom where there is only the head of the bolt.??? LIkei dont see them come up into the body of the jeep like they did with my Explorer when i lifted it
Brindle19 is offline   Reply With Quote
Glock Forum
