Body lift - JeepForum.com
post #1 of 3 Old 03-18-2002, 01:38 PM Thread Starter
vandall
Body lift
Just installed a 3" body lift on 89 wrangler. I used the performance accesories lift. This lift came complet with eveything needed. It is a good idea if you are going to do this yourself, to have a welder lined up to weld you upper shift linkage (Automatic), and you 4WD shifter. Other then that it is really easy.
89 wrangler, 4.2 auto 33"sidewinders, 3 in body lift,
vandall is offline
post #2 of 3 Old 03-23-2002, 01:48 PM
blackyj
blackyj's Avatar
HOW DO THE 33" TIRES FIT WITH THE 3" LIFT?
BLACK 95 YJ 2.5L 31X10.5 TRXUS M.T, HOME MADE FRONT BUMPER,HOME MADE REAR BUMPER WITH SWING AWAY TIRE CARREIR,OLYMPIC NERF BARS,HILIFT,KC LIGHTS,BEST TOP REPLACE-A-TOP WITH TINTED WINDOWS,lots of diamond plate, DYNOMAX MUFFLER, ELECTRIC COOLING FAN, JUNK YARD POWER STEERING,and a 2" body lift.2"add a leaf. 2002 grand cherokee, 77 cj5 32x11.5x15 m.t. 4"trailmaster, 2"shackles fiberglass everything,hardtop,bestop seats.
blackyj is offline
post #3 of 3 Old 03-24-2002, 04:13 PM
FunkSkunk
Sold my soul to JeepForum
FunkSkunk's Avatar
Vandall
Where you able to get the front grill lift brackets in without unbolting the grill? I have tried and tried to push those bad boys in but the rubber pad is just too big. Just curious to know if you just left those off completely.
do you have any pics of it lifted?
FunkSkunk is offline
Body Mount/Body Lift problems need help! muddy8jeep8 TJ Wrangler Technical Forum 0 02-03-2009 02:53 PM
JK Body Lift? Rock Sliders Move WITH BODY? trowand JK Wrangler Technical Forum 17 01-04-2009 03:34 PM
Installing body lift, Cant get the front body mount off... swsscb TJ Wrangler Technical Forum 3 11-07-2008 09:23 PM
Body mount damage - Body lift help Drew43 TJ Wrangler Technical Forum 5 01-31-2007 08:39 AM
to body lift or not to body lift? atlas trouble twistedtj TJ Wrangler Technical Forum 9 08-21-2003 12:35 AM
