body lift - JeepForum.com
post #1 of 3 Old 09-13-2001, 04:24 AM Thread Starter
bonehead99
bonehead99's Avatar
body lift
I just got my new body lift and the directions are hard to understand. It says I have to drill out a pin in the steering linkage. Is this correct? It also said I have to make a linkage extension, true? In the kit their are some flat metal pieces with a bolt going through one end, what are these for? Also their is a peices on round steel about 4-5in long, what is this? Sorry I'm new at this and the direction consist of about 10 sentences!
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #2 of 3 Old 09-13-2001, 07:28 AM
Cody_91YJ
Well, your kit sounds a bit different from mine, but lets see....
If you have any auto, you are going to have to mess with the linkage, and I'm not sure what all that involves, I've got the 5spd.
The flat metal peices with a bolt in them, should also have a hole on the other end, and that is probably the radiator drop kit.
How much lift is the kit and who made it?
'91 YJ Mangler w/ too many mods...and yet not enough ;)
Cody_91YJ is offline
post #3 of 3 Old 09-13-2001, 12:18 PM Thread Starter
bonehead99
bonehead99's Avatar
Its a 3in kit I can't remember the name but it started with a D. I do have an auto, the linkage has already been modified to fit a Pacesetter Armor-coated header.
Body Mount/Body Lift problems need help! muddy8jeep8 TJ Wrangler Technical Forum 0 02-03-2009 02:53 PM
JK Body Lift? Rock Sliders Move WITH BODY? trowand JK Wrangler Technical Forum 17 01-04-2009 03:34 PM
Installing body lift, Cant get the front body mount off... swsscb TJ Wrangler Technical Forum 3 11-07-2008 09:23 PM
Body mount damage - Body lift help Drew43 TJ Wrangler Technical Forum 5 01-31-2007 08:39 AM
to body lift or not to body lift? atlas trouble twistedtj TJ Wrangler Technical Forum 9 08-21-2003 12:35 AM
