Body lift - Page 2 - JeepForum.com
post #16 of 21 Old 10-16-2001, 06:23 PM
iJeep
[quote]Originally posted by RodeoRob:
Originally posted by Capa:
$300 is a lot to pay for a body lift. I paid $80 for my 3" body lift... granted that wasn't installed, but...
If you're looking at spending that much money, go a little further and get a 3.5"-4" suspension lift. Rustys sells a 3.5" kit for ~$400. You'll be happier in the long run with a suspension lift.
-Rob
Most places charge more to install a BL than suspension lift because there are a lot of little things that are a pain and they would rather do something that works out smooth and will not cause problems that they will have to repair free of charge in the future.
iJeep is offline
post #17 of 21 Old 10-16-2001, 09:19 PM Thread Starter
Keymaster
Keymaster's Avatar
Wow...I appreciate all the input. I think I may take the advice of of SBgreenYJ. From what everyone is telling me, raising my rig on stilts like that is uncool, so I may opt to just stay with my new 31" B.F. Goodrich tires and buy some rims to go along with them. I don't want to compromise anything on my Jeep and without the funds to drop another 400 bucks for a decent lift, I will have to be content with what I have for now. If I could throw a couple of more questions out there though, 1. Would a 15x10 rim be okay to buy for 31" tires, just in case I want to eventually go to a bigger tire and 2. Would a 1 to 1.5" shackle lift be enough to give me an adequate boost in lift? I have a slight rubbing problem now like Capa mentioned so I want to raise it slightly.
1997 F-150
2000 Ford Explorer
Looking for a YJ!
Keymaster is offline
post #18 of 21 Old 10-16-2001, 09:44 PM
RodeoRob
RodeoRob's Avatar
Well, the width of the tire is much more of a concern than the height. what are you looking at? 31 x 9.50s? For pretty much any width 31" tire, you're gonna want to stay away from a 15x10 rim. I wouldn't recommend a wide rim like that to anyone unless they are running wider than a 12.50" tire. you'll most likely wanna stay with 15x7 or maybe 15x8. If the rim width is close to the tire width, the tire will be more prone to loosing a bead. Also, have a good gab between rim and tire width will ensure the tire protects the rim (sidewall buldge).
yea, if you're looking to clear 31's, a 1-2" lift should be adequate.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #19 of 21 Old 10-16-2001, 09:55 PM
Capa
Damn I got 31x 10.5's when I got my jeep, and was told that 15x10 wheels would fit good. I got a great deal on some Weld Typhoons, so I have 15x10 rims on 31x10.5 tires. I do need new tires soon though, I guess I'll see about going to 12.5 wide.
How much would a shackle lift cost, and how hard is it to put on?
Capa is offline
post #20 of 21 Old 10-16-2001, 10:23 PM
RodeoRob
RodeoRob's Avatar
Go to a place like www.quadratec.com and do a search on 'YJ lift shackle'. You'll come up with several companies that make em. You're looking at slightly over $100 for 4 shackles (front/rear).
Anybody willing to turn a wrench can install a shackle lift. Its just a matter of unweighting the axle, removing the bolts that hold the spring to the shackle and then shackle to the frame, and then putting the new one in. easy.
-Rob
Robert Gorrell
RodeoRob is offline
post #21 of 21 Old 10-16-2001, 10:25 PM
RodeoRob
RodeoRob's Avatar
I should add, if you are gonna do a shackle lift and replace the stock shackles, it might be a good idea to spend a few extra bucks and get the greasable shackles. They're not that much more expensive and it will eliminate lots of squeeks you get from the suspension.
-Rob
Robert Gorrell
RodeoRob is offline
Body Mount/Body Lift problems need help! muddy8jeep8 TJ Wrangler Technical Forum 0 02-03-2009 03:53 PM
JK Body Lift? Rock Sliders Move WITH BODY? trowand JK Wrangler Technical Forum 17 01-04-2009 04:34 PM
Installing body lift, Cant get the front body mount off... swsscb TJ Wrangler Technical Forum 3 11-07-2008 10:23 PM
Body mount damage - Body lift help Drew43 TJ Wrangler Technical Forum 5 01-31-2007 09:39 AM
to body lift or not to body lift? atlas trouble twistedtj TJ Wrangler Technical Forum 9 08-21-2003 01:35 AM
