Body lift - JeepForum.com
post #1 of 10 Old 07-04-2013, 04:53 PM Thread Starter
moeller26
Body lift
Should I get a 3" body lift? I have a 4" suspension and 35" tires
moeller26 is offline
post #2 of 10 Old 07-04-2013, 05:14 PM
FunkyJeepz
One of the most dreaded things in the jeep world. What would make you want more lift? Are you rubbing?
FunkyJeepz is offline
post #3 of 10 Old 07-04-2013, 05:28 PM
HighRoller02TJ
1.25" is the most you should go on a body lift
HighRoller02TJ is offline
post #4 of 10 Old 07-04-2013, 05:50 PM Thread Starter
moeller26
Will that stop my tires from rubbing?
post #5 of 10 Old 07-04-2013, 05:55 PM
HighRoller02TJ
when are they rubbing? when flexing? or turning on the street?
post #6 of 10 Old 07-04-2013, 05:56 PM
HighRoller02TJ
when my TJ had just a 2.5" suspension and 33s it didn't rub. I doubt you need a 4" suspension and 3" BL for 35s
post #7 of 10 Old 07-05-2013, 09:12 AM
Siva283
IF the suspension lift is a quality 4 inch lift not the rough contry garbage. You should be able to add the 1.25 inch body lift and be good as far as flexing goes. If it rubs when you turn you eithier need wheel spacers ot you can adjust your steering stops.
Ask me how I know...
Siva283 is offline
post #8 of 10 Old 07-05-2013, 09:48 AM
UZI4U
Get a Daystar 1" and do it right the first time. I have a BDS 3.5" lift and the DS 1" and I could fit 35's easily without rubbing. It might when flexing, but I don't get out that much.
MCLMM
UZI4U is offline
post #9 of 10 Old 07-05-2013, 10:00 AM
DaveS01
Or a numerically lower backspacing..
DaveS01 is offline
post #10 of 10 Old 07-06-2013, 01:10 PM
jagular7
Use tj flares can make room for 35's both front and rear. To compliment the rear tj flares, use aftermarket flat fenders.
Replacing the worn out ruby mounts with new polys helps too. I wouldn't go any higher than 1.25" poly bushings to replace the stockers.
Mike
Jagular
Lnxa, KS
97 TJ SE lifted, locked and rubbered for fun
94 YJ SE stock, 225s, Trail Tested
jagular7 is offline
