Body Lift - JeepForum.com
post #1 of 15 Old 04-24-2013, 03:07 AM Thread Starter
diaz425
Body Lift
I had bought a 1.25 rough country body lift. When I was loosening the bolts 3 have broken off (sucks). And with the body lift kit that I bought I would have to reuse the old bottom bushings. I'm just going to return the kit and buy the 1in kit (cost more) but comes with new bottom bushing, washers, etc. Do I need to reuse any older parts to install new kit or does everything comes with the 1in body lift kit (for those of you who has the kit)?
Which would you recommend Daystar (KJ04505BK) $130 or Rough Country (RC609) $158?
Thanks
diaz425 is offline
post #2 of 15 Old 04-24-2013, 05:01 AM
zte87
GIVE IT THE ONION
zte87's Avatar
Thanks
I love my daystar kit if that helps.........it came with everything as well!
zte87 is offline
post #3 of 15 Old 04-24-2013, 06:24 AM
StanF
+1 on the Daystar Kit. Amazon has the best price on it, I think.
I like the Daystar Kit because it replaces all the existing isolators. It doesn't just add a new spacer on top of your old isolators. For the age of our Jeeps, full replacement is better, of course.
StanF is online now
post #4 of 15 Old 04-24-2013, 12:24 PM Thread Starter
diaz425
here is a review someone posted about the daystar 1in lift:
" Installing this kit on my 1994 Wrangler was pretty straight forward. My existing rubber body mounts were mostly rotted out. These pieces seem like they will last for a long time. I wish it included the factory mushroom shaped bushings that are needed (even if they were an option that costs extra)."
http://www.amazon.com/Daystar-KJ0450...owViewpoints=1
what is he talking about the mushroom bushing?
diaz425 is offline
post #5 of 15 Old 04-24-2013, 02:24 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The steel sleeve that the bolt slips through. You need to reuse that piece but the more rotten your stock bushings, the easier it is to extract.
Luck Favours The Prepared
Anticanman is offline
post #6 of 15 Old 04-24-2013, 02:43 PM Thread Starter
diaz425
where can i that the steel sleeve? I might to to replace those to right?
diaz425 is offline
post #7 of 15 Old 04-24-2013, 02:48 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
They're probably ok unless your jeep looks like rusty Swiss cheese. They're more of a bushing and small spacer for the bolt to pass through the bushings into the body. Do you have a picture of your current body mounts up close?
post #8 of 15 Old 04-24-2013, 03:12 PM Thread Starter
diaz425
rear bumber driver side
diaz425 is offline
post #9 of 15 Old 04-24-2013, 03:31 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I'm sure you can clean them up. If your time is more valuable, then buy a set so you don't have to separate.
post #10 of 15 Old 04-24-2013, 03:38 PM Thread Starter
diaz425
that is the sleeve you're talking about right? what is the name for that part just in case I end up buying it?
I'm just waiting for rough country to email back with an rga number to return my 1.25in kit to send back and order the daystar 1in kit
thanks all for your help.
diaz425 is offline
post #11 of 15 Old 04-24-2013, 03:42 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
They are the steel washer bushings. I don't know the real name for them nor do I have a picture from when I did mine.
post #12 of 15 Old 04-26-2013, 03:59 AM Thread Starter
diaz425
i found this kit. it doesn't say to reuse steel cup sleeve like daystar instruction says. brand is prothane.
Screenshot from 2013-04-26 04:52:27.jpg
diaz425 is offline
post #13 of 15 Old 04-26-2013, 06:10 AM
Louie4
Here is a thread about those sleeves:
http://www.jeepforum.com/forum/f12/b...leeves-812132/
Here is Que's post about part numbers from the dealership:
Originally Posted by Que89YJ View Post
I called a different stealership and I am happy to report that the price I got the second time was much more reasonable:
(6) 5200 1961 Retainer(Bushing Sleeve) retail price $9.55ea. discount
(4) 5200 2661 Retainer(Bushing Sleeve) retail price $7.16ea. discount
It pays to check around even at dealerships. The first dealership was about $160.00 for all the sleeves. I called around this morning after looking for piping to make my own last night with no luck. My cost for all of them comes out to about $90.00.
I looked around for piping that matched the same Outer Diameter of the sleeves and would be snug in the bushing and I didn't have any luck. If anyone can come up with a good source it woud be good info to have posted here. I was really getting frustrated with these bushings. I seriously recommend anyone buying a kit to make sure the sleeves are included or find another kit.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #14 of 15 Old 04-26-2013, 08:42 AM
TSEJEEPERS
This is the one I used.
Everything is included.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is online now
post #15 of 15 Old 04-26-2013, 09:47 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It replaces the mushroom washers with steel bushings and separate flat washers. Same concept, really.
