Body lift? - JeepForum.com
post #1 of 22 Old 01-26-2012, 07:28 PM Thread Starter
Cjason
Body lift?
I hve 4inch suspension lift on my 90 yj want few more inches ........any help on if its a good idea and how easy it will b? Thanks
Cjason is offline
post #2 of 22 Old 01-26-2012, 10:38 PM
y87j
1987 YJ Wrangler
I am in the same boat I have 33 with 4in lift with tire rub whats the best lift...and any threads to get boltsout ?they are rusted
y87j is offline
post #3 of 22 Old 01-26-2012, 10:42 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Want or need? What size tire? What brand lift? Fill out your profile please
Luck Favours The Prepared
Anticanman is offline
post #4 of 22 Old 01-26-2012, 10:44 PM
timatoe
timatoe's Avatar
I took out a 2" bl without much effort. I imagine putting one in would be more difficult, but not very.
timatoe is online now
post #5 of 22 Old 01-26-2012, 10:45 PM
jeepyj13
Got 33s? Put a 1" BL.Mostly will say thats as high as you should go which i agree on.You can also put some lift shackles like 5/8-1" with 1" being what most will say being the limit. Or do some trimming and put some tj or aftermarket flares on. I knw yoy asked for BLs but those are some options i just put out there for you Thats my 2cents
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #6 of 22 Old 01-26-2012, 10:50 PM
y87j
1987 YJ Wrangler
Originally Posted by jeepyj13 View Post
Got 33s? Put a 1" BL.Mostly will say thats as high as you should go which i agree on.You can also put some lift shackles like 5/8-1" with 1" being what most will say being the limit. Thats my 2cents
With the 1in bl I wont get any tire rub? I have no fender flares to give it extra space
y87j is offline
post #7 of 22 Old 01-26-2012, 11:16 PM
jeepyj13
not really a BL guy but with a 4" spring a 1" BL is sometimes all you need just to completely clear tires esp. 33s. i see you got RC by your profile right? i have the same RC(as of now) i recently added 1" lift boomerang shackles addition to the 4" springs to give some more clearance. in reality it may only lifted 1/2" more. i added aftermarket flares but i nvr got around trimming fenderwells. i can stuff the 33s good before actually rubbing the untrimmed space. if i were to trim i probably wouldnt rub. there are other things you can do to help prevent rubbing along with just adding a BL such as lift shackles and tj flares are a few great mods. good luck with the build
jeepyj13 is offline
post #8 of 22 Old 01-26-2012, 11:38 PM
timatoe
timatoe's Avatar
I'd suggest looking into doing TJ flares before doing a body lift. 4" springs and TJ flares should fit 33's with no issue. If not, get better springs.
post #9 of 22 Old 01-27-2012, 12:29 PM
y87j
1987 YJ Wrangler
its not the flares i am worried about .. i have no flares on now... its the wheel whell i cant clear i dont get a goo flex because the tire hits the back corner before it tucks
y87j is offline
post #10 of 22 Old 01-27-2012, 02:51 PM
WakeDoctor
This tread is so horrible it is humorous. You teenagers really need to learn to utilize sentence structure. I find it funny how someone can type a whole paragraph and manage to capitalize BL several times, but not one other word.
y87j, Fix/extend your bump stops you won't rub any more.
WakeDoctor is offline
post #11 of 22 Old 01-27-2012, 03:07 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
What isn't being addressed is there is significant cutting to install tj flares.
About this much to be exact.
See sig for grammatical complaints.
post #12 of 22 Old 01-27-2012, 03:12 PM
scramjeepbler
Junior Member
lift kit no body lift
I have a 4 lift with 1 1/2 lift shackles Im running 33 x 12.50 x 15 on ultra 15 x 10 rim with no body lift no tire rub . you need offset rims or wheel spacers . I did run 31 x 9.50 x15 trxus m/t on stock canyon wheels with tire rub on front only . went to wider tire & rim with offset no rub at all
scramjeepbler is offline
post #13 of 22 Old 01-27-2012, 03:56 PM
ptrcrynn
there is a thread on removing those bolts if there rusted you will have to use search. It shows you the exact location to drill in tub above each bolt so you can soak in PB Blaster. I'm not looking foward to it.
ptrcrynn is offline
post #14 of 22 Old 01-27-2012, 05:28 PM
devoX13
What I ran into when I removed mine was not rusted bolts. I started soaking mine 2 weeks before we started our project. But the threaded piece on the tub side was spinning.
devoX13 is offline
post #15 of 22 Old 01-27-2012, 06:04 PM
jeepyj13
Im not worried about your insult. Its a forum not a serious deal, so I dont care about the grammer on here. Just trying to suggest, but I assume you all have that covered hopefully. The thing I found "humorous" about your post though I'm not a teen either haha. Good day to you all.
jeepyj13 is offline
