Body bolt torque - JeepForum.com
post #1 of 6 Old 04-29-2001, 12:03 AM Thread Starter
Keith
Admin
Keith's Avatar
Body bolt torque
What's the torque on the body bolts? I guess a huge shop manual would have it but my Haynes manual doesn't list it. Also is there a web site full of torque information.
A/S/L me
Keith is offline
post #2 of 6 Old 04-29-2001, 12:15 AM
Tonka
2015 JK Wrangler
I need to know too, I just did a 1in bodylift today(waiting for an axle shaft to arrive)
I also need to know how to remove the broken bolt/ nut from the drivers rear corner(easy outs didn't work)
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #3 of 6 Old 04-29-2001, 11:54 AM
osburn
osburn's Avatar
I just helped with a body lift yesterday. We just tightened the bolts. Just get'm tight. I don't think it's actually that crucial.
On the broken bolt, what's always worked best for us, is to place a nut over the bolt and weld the center of the nut to the bolt.
Matt Osburn
Score 1032
osburn is offline
post #4 of 6 Old 04-29-2001, 07:34 PM
Tonka
2015 JK Wrangler
The problem is that the bolt broke off flush with the nut.
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #5 of 6 Old 04-30-2001, 12:10 AM
osburn
osburn's Avatar
If there's any meat above the nut, maybe you could get some vice grips on it. Or, cut it out and weld a new nut in there I suppose.
Matt Osburn
Score 1032
osburn is offline
post #6 of 6 Old 04-30-2001, 07:12 AM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
Hammer & chisel to try to catch an edge of the chisel on the broken part and have it turn out......
Otherwise, drill and retap, and cuss a lot!
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
Body Lift Bolt Torque Spec rhbickham TJ Wrangler Technical Forum 6 07-29-2013 05:48 PM
Torque converter bolt torque misprint! planedog YJ Wrangler Technical Forum 7 03-16-2009 11:48 AM
Bolt Torque? Capeman29 TJ Wrangler Technical Forum 8 04-16-2008 03:39 AM
Body Bolt Torque Question Jeebs YJ Wrangler Technical Forum 1 03-13-2008 05:52 PM
What's the name of this bolt & torque? Thunderstrike TJ Wrangler Technical Forum 2 01-26-2006 06:55 PM
