Body Armour? - JeepForum.com
post #1 of 11 Old 02-24-2009, 07:03 AM Thread Starter
KnightofMopar
Body Armour?
Looking for a few pieces of body armour for my 90 yj. When I bought the jeep it already had the side pieces on it, but what I really need/want is the back corner pieces and one for the front grill. I have seen TONS of TJ styles for the back, but it has a hole for the gas tank on the wrong side . Any help would be appreciated!
KnightofMopar is offline
post #2 of 11 Old 02-24-2009, 07:40 AM
JaikYJ
If you really want you can get the TJ ones and just move your fuel filler to the side and you wont have to wrestle with your license plate whenever you fill up.
https://www.polyperformance.com/shop...ch-p-2353.html
http://www.genright.com/category.aspx?categoryID=142
87 YJ(sold), 97 TJ(sold), 99 TJ(daily)
03 R1 (fun)68 Mustang Coupe(summer)
67 Fastback(resto)
JaikYJ is offline
post #3 of 11 Old 02-24-2009, 07:40 AM
doubleroost
doubleroost is offline
post #4 of 11 Old 02-24-2009, 07:58 AM
Exparrot
Exparrot's Avatar
I have these (http://www.quadratec.com/products/12515_XXX_PG.htm) in 12-gauge steel. Haven't gotten them installed yet, but they're beefy enough for what I need.
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline
post #5 of 11 Old 02-24-2009, 08:59 AM
0359887
check out vendors.... sniper fab has some nice rear tube fenders that bolt around the rear corners... also fabricate a yj friendly version
0359887 is offline
post #6 of 11 Old 02-24-2009, 09:12 AM Thread Starter
KnightofMopar
Thanks guys! How hard is it to move the gas filler? I am looking for a diamond plate style, and do NOT want the ones that go the full way around, just enough to cover the corners in the back. Thanks so much for the help so far guys!
post #7 of 11 Old 02-24-2009, 09:20 AM
texas_yj
I got the full DP ones, but qtec has the short diamond plate ones too
Sold) 94 YJ, 4.0L 5 sp manual, Hard top, 33/12.50s, 4.10 ring&pinions, Polished D30 w/Aussie front, 8.8 rear w/ LS, 2.5" RC, 2" BL, 5/8" booms, TJ flares, SYE, custom F/R bumpers and rock sliders, 8k winch, dual optimas, HO alt.
2) (Sold) 99 TJ, mustang 5.0 GT 40, AX15/231J, trektop, 37x12.50r17 cooper STT, superlift 6" long arm, D30/44 w/ ARBs & yukons, customized warn bumpers, custom sliders, 12K winch w/ synthetic rope, custom paint
3) 2007 JKU being built now
texas_yj is offline
post #8 of 11 Old 02-24-2009, 09:45 AM
doubleroost
When I first bought my yj the one rear corner was dented, and when i pulled it out all the paint cracked. Rather then get corner guards, I took spray on bed liner and did just the corners. I really liked how they came out and it only cost me $5. And the LED lights are just trailer lights from harbor freight $20 a piece.
post #9 of 11 Old 02-24-2009, 09:54 AM
jeepster93
jeepster93's Avatar
Went with Genright, myself. Got the full coverage ones as they are certainly armor. Also had future plans on further mods. These plans needed the full coverage corners.
Added home made weld on armor plate flairs, moved the license plate and added led lights.
jeepster93 is offline
post #10 of 11 Old 02-24-2009, 09:58 AM
Joshhamburger
ive got a set of tj one and moved the gas filler over. All the yj guys will tell you to do the filler relocation a bit lower than the normal tj to avoid the wheel well inside the cab, but if you get the corner guards youll have to put the filler in the stock location and cut into the wheel well.
Joshhamburger is offline
post #11 of 11 Old 02-24-2009, 11:52 AM
Exparrot
Exparrot's Avatar
These are the short corners...
http://www.quadratec.com/products/12515_1X_PG.htm
Exparrot is offline
jeep armour? mercab18 TJ Wrangler Technical Forum 9 05-23-2009 08:07 PM
body armour for 02 TJ jeepin_in_fl TJ Wrangler Technical Forum 13 12-06-2008 12:26 PM
How are Body Armour with swing out? jrnjay YJ Wrangler Technical Forum 7 02-02-2006 01:08 PM
What to armour first? Giviner TJ Wrangler Technical Forum 37 12-08-2005 10:44 AM
Rust behind body armour? Korruptor TJ Wrangler Technical Forum 10 10-23-2005 10:34 AM
