Bob's Build Thread - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Bob's Build Thread
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 04-27-2011, 07:22 PM   #31
cubewhiz
Dust cover plate came in the mail today.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
[URL="http://www.jeepforum.com/forum/f12/bobs-build-thread-1081112/"]My Build Thread[/URL]
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline   Reply With Quote Quick reply to this message
Unread 04-30-2011, 10:48 AM   #32
cubewhiz
I ordered the clutch parts for my 6.0L Swap:
- Flywheel & Clutch Kit (AA)
- Hydraulic Hose & Fitting (AA)
- Bellhousing Bracket (AA)
- Slave Cylinder (AA)
- Clutch Fork (GM)
I also got my bellhousing & dust shield in the mail:
Unread 06-07-2011, 05:06 PM   #33
cubewhiz
The engine is here. I also ordered the radiator, e-fan, motor mounts, & Novak shifter. Engine will be out soon.
Unread 06-13-2011, 09:00 PM   #34
cubewhiz
I got some goodies in the mail from Novak today:
Electric Fan
Motor mounts & shifter
Shift Boot
Radiator
Unread 06-13-2011, 09:33 PM   #35
Noltz
YJ Wrangler
Mm... delicious parts.
You'll be fine with the engine. Document the engine number, keep the receipts for everything. You'll need all the emissions components that the Denali had, which your 95 YJ already has. Evap canister with purge control, sealed fuel system, and the computer to control it all (including EGR if the 6.0 has one). You'll also likely need 2 cats.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline   Reply With Quote Quick reply to this message
Unread 06-13-2011, 11:01 PM   #36
cubewhiz
by this you mean the GM computer, right? I'm not yet sure if I'm retaining the Jeep computer.
Unread 06-15-2011, 10:07 PM   #37
cubewhiz
Got my F-body oil pan and pickup tube in the mail today!
Unread 07-29-2011, 04:27 PM   #38
cubewhiz
I'm almost done rebuilding the SM465. I got the wiring harness and computer off and ready to ship to Jim's Performance. The 2.5's last days are here. It should be out within a week or so.
Unread 08-22-2011, 10:36 PM   #39
jvallery
So I'm using the same tranny in my setup. I'm still a bit confused about what all I'll need. The tranny was rebuilt a few years ago so I'm not itching to crack the case open. I bought the same kit you did from AA. What else do I need in terms of the clutch assembly and hydraulics to make it work?
jvallery is offline   Reply With Quote Quick reply to this message
Unread 08-22-2011, 11:12 PM   #40
cubewhiz
Hrmm. Well, what T/C and T/c adapter are you using? If you're using the NP231 with Novak's adapter (which I'm pretty sure I remember you saying you are), you'll have to open the case anyway because it uses a new mainshaft. You should only need to take out the input and mainshafts. Take everything on your mainshaft and put it on the Novak mainshaft that came with your adapter and put them back in.
I'm using this:
- AA Clutch Kit (712500M)
- AA Slave cylinder (716213)
- AA Slave cylinder bracket (716286) - doesn't fit my bellhousing...gotta do something about that
- AA Pilot Bushing (716170)
- AA Hydraulic Hose & Fitting (716130H & 716130F)
- GM Clutch Release Arm (GM #3765372)
Transmission is almost put back together.
Just need the input shaft back in and I'm good to go.
Unread 08-22-2011, 11:15 PM   #41
jvallery
Yup - NP231 with Novak adapter. Sounds fun..... :-(
Unread 08-22-2011, 11:29 PM   #42
jvallery
Ordered.. Another $241 I wasn't planning on spending :-)
What is your total project budget? With that order I officially hit $10k spent so far.
Unread 08-23-2011, 12:11 AM   #43
cubewhiz
Was the $241 clutch stuff?
I'm at $5460 for the swap so far. $10k isn't just for the swap I hope. I can't see myself spending another $5k. I have just about everything I expect I need.
Unread 08-23-2011, 12:31 AM   #44
jvallery
Ya - $241 for the clutch stuff.
You're right the $10k includes a bunch of other stuff as well. It's a complete tub off restore so I'm buying stuff as I go. I bet I have another $5k to go before I'm done. I should have just bought a new JK :-)
Unread 08-23-2011, 12:58 AM   #45
cubewhiz
But where's the fun in that?
