Bob's Build Thread - Page 3 - JeepForum.com
post #31 of 68 Old 04-27-2011, 06:22 PM Thread Starter
cubewhiz
Dust cover plate came in the mail today.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #32 of 68 Old 04-30-2011, 09:48 AM Thread Starter
cubewhiz
I ordered the clutch parts for my 6.0L Swap:
- Flywheel & Clutch Kit (AA)
- Hydraulic Hose & Fitting (AA)
- Bellhousing Bracket (AA)
- Slave Cylinder (AA)
- Clutch Fork (GM)
I also got my bellhousing & dust shield in the mail:
cubewhiz is offline
post #33 of 68 Old 06-07-2011, 04:06 PM Thread Starter
cubewhiz
The engine is here. I also ordered the radiator, e-fan, motor mounts, & Novak shifter. Engine will be out soon.
cubewhiz is offline
post #34 of 68 Old 06-13-2011, 08:00 PM Thread Starter
cubewhiz
I got some goodies in the mail from Novak today:
Electric Fan
Motor mounts & shifter
Shift Boot
Radiator
cubewhiz is offline
post #35 of 68 Old 06-13-2011, 08:33 PM
Noltz
YJ Wrangler
Mm... delicious parts.
You'll be fine with the engine. Document the engine number, keep the receipts for everything. You'll need all the emissions components that the Denali had, which your 95 YJ already has. Evap canister with purge control, sealed fuel system, and the computer to control it all (including EGR if the 6.0 has one). You'll also likely need 2 cats.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #36 of 68 Old 06-13-2011, 10:01 PM Thread Starter
cubewhiz
by this you mean the GM computer, right? I'm not yet sure if I'm retaining the Jeep computer.
cubewhiz is offline
post #37 of 68 Old 06-15-2011, 09:07 PM Thread Starter
cubewhiz
Got my F-body oil pan and pickup tube in the mail today!
cubewhiz is offline
post #38 of 68 Old 07-29-2011, 03:27 PM Thread Starter
cubewhiz
I'm almost done rebuilding the SM465. I got the wiring harness and computer off and ready to ship to Jim's Performance. The 2.5's last days are here. It should be out within a week or so.
cubewhiz is offline
post #39 of 68 Old 08-22-2011, 09:36 PM
jvallery
So I'm using the same tranny in my setup. I'm still a bit confused about what all I'll need. The tranny was rebuilt a few years ago so I'm not itching to crack the case open. I bought the same kit you did from AA. What else do I need in terms of the clutch assembly and hydraulics to make it work?
jvallery is offline
post #40 of 68 Old 08-22-2011, 10:12 PM Thread Starter
cubewhiz
Hrmm. Well, what T/C and T/c adapter are you using? If you're using the NP231 with Novak's adapter (which I'm pretty sure I remember you saying you are), you'll have to open the case anyway because it uses a new mainshaft. You should only need to take out the input and mainshafts. Take everything on your mainshaft and put it on the Novak mainshaft that came with your adapter and put them back in.
I'm using this:
- AA Clutch Kit (712500M)
- AA Slave cylinder (716213)
- AA Slave cylinder bracket (716286) - doesn't fit my bellhousing...gotta do something about that
- AA Pilot Bushing (716170)
- AA Hydraulic Hose & Fitting (716130H & 716130F)
- GM Clutch Release Arm (GM #3765372)
Transmission is almost put back together.
Just need the input shaft back in and I'm good to go.
cubewhiz is offline
post #41 of 68 Old 08-22-2011, 10:15 PM
jvallery
Yup - NP231 with Novak adapter. Sounds fun..... :-(
jvallery is offline
post #42 of 68 Old 08-22-2011, 10:29 PM
jvallery
Ordered.. Another $241 I wasn't planning on spending :-)
What is your total project budget? With that order I officially hit $10k spent so far.
jvallery is offline
post #43 of 68 Old 08-22-2011, 11:11 PM Thread Starter
cubewhiz
Was the $241 clutch stuff?
I'm at $5460 for the swap so far. $10k isn't just for the swap I hope. I can't see myself spending another $5k. I have just about everything I expect I need.
cubewhiz is offline
post #44 of 68 Old 08-22-2011, 11:31 PM
jvallery
Ya - $241 for the clutch stuff.
You're right the $10k includes a bunch of other stuff as well. It's a complete tub off restore so I'm buying stuff as I go. I bet I have another $5k to go before I'm done. I should have just bought a new JK :-)
jvallery is offline
post #45 of 68 Old 08-22-2011, 11:58 PM Thread Starter
cubewhiz
But where's the fun in that?
cubewhiz is offline
Not really a build thread jeffa187 TJ Wrangler Technical Forum 10 09-09-2010 07:07 AM
95 YJ GOING BIG BUILD THREAD Here ya go!!!!! highrolrcustoms YJ Wrangler Technical Forum 34 03-26-2010 01:26 PM
My build thread.:) ImportEater YJ Wrangler Technical Forum 49 03-18-2009 05:38 PM
Fat Bob's Garage 10% off emev0l Wrangler General Discussion 4 02-22-2009 09:09 PM
My 90 YJ Build Thread WMiller13 YJ Wrangler Technical Forum 9 12-14-2008 04:51 PM
