Bob - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Bob
Iron Rock Offroad products - get them from Kolak!TERAFLEX JKU 2.5" Elite LCG Long FlexArm Lift Kit w/ March Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATE
Unread 10-09-2014, 12:43 PM   #1
Bobbb
Bob
My rear brake pads are down to .002 and the front is at .008. Is that normal. Shouldn't the wear be 60/40 the other way. It's a 2012 sport Wrangler with 34995 miles. Shouldn't this be covered by warranty?
Bobbb is offline   Reply With Quote Quick reply to this message
Unread 10-09-2014, 01:01 PM   #2
jaycal3
jaycal3's Avatar
Wrong forum for your jeep..... And brake pads are a wear item-I've never known them to be covered under a warranty.
Sent from my iPhone using JeepForum... So excuse the typos, my iPhone is challenged.
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
http://mskcc.convio.net/goto/Jay_Calabrese
KCCO
jaycal3 is offline   Reply With Quote Quick reply to this message
Unread 10-09-2014, 01:29 PM   #3
mike134
It depends on the quality of the pads and rotors being used. A lot of times you can get away with only changing the front brakes the first time, and getting to the back at the second change. Not always. Just replace them all if they are worn, it doesn't cost much.
Wear rate depends on how you drive. If you drive 20 mph over the speedlimit and keep hitting the brakes because you are tailgating or weaving in and out of traffic, you are going to need a lot of brake pads. Change your driving habits...
mike134 is offline   Reply With Quote Quick reply to this message
Unread 10-10-2014, 08:32 PM   #4
DirtKar
I pledge allegiance.
DirtKar's Avatar
You have 35 thousand miles on your Jeep, Bob. Change your pads.
What you see as not bad, and what I see as not bad, are two completely different not bads
YJOTM JULY 2014
DirtKar is offline   Reply With Quote Quick reply to this message
Unread 10-11-2014, 07:44 AM   #5
metalhead
If I remember correctly from when I was a mechanic at a jeep dealership, brake pads are only covered for 1 year.
metalhead is offline   Reply With Quote Quick reply to this message
Unread 10-11-2014, 08:09 AM   #6
Myjeep1986
Brake Pads
It is a wear item and owner responsibility: On my daily I have 98k and still on original brakes-depends on your foot/driving habits. The brides on the other hand is heavy on the brake-ugh!!
Myjeep1986 is offline   Reply With Quote Quick reply to this message
