On Board Air System - JeepForum.com
post #1 of 14 Old 08-28-2005, 11:02 AM Thread Starter
fastone110
fastone110's Avatar
On Board Air System
i want to get the OBA system on my jeep.. i went offroading the other day took air out of my tires and later got done wheeling and i had to drive a mile to a gas station to air the tires up.. with my 4cyl being pretty weak if i put the belt drivin compressor on, will it effect performance.. on and offroad? i have a serpantene belt i think.. i was think about buying a york compressor and i was wondering if it will mount to my engine with proper brackets and a new belt.
i was also thinking of making a tank out of my rear bumber.. later
'88 yj wrangler 2.5L /w 3.5 black diamond suspension lift, 2" body lift, 1 1/4" shackles, detroit gearless front locker, lockright in rear, posi-lok, traction bars off, no sway, 35x12.50x15 baja claws on homemade beadlocks, 4.10 gears protected by homemade diff covers, TFI, herculined, 8000lb winch, GenRight Bumbers, BrownDog 1''MML, JB SYE, flowmaster, custom YJ dash, kicker 4" front speakers, sony explode cd player, rocker panel guards, custom SS red brake lines.
fastone110 is offline
post #2 of 14 Old 08-28-2005, 03:46 PM Thread Starter
fastone110
fastone110's Avatar
can somone help me plz
post #3 of 14 Old 08-28-2005, 03:49 PM
xeon
When the compressor is on, it will pull power from your motor. But the compressor wont be on when you are wheeling or driving. So then you wont loose power. It is a very simple setup. Here is a great site for OBA.
http://www.onboardair.com
Hope this helps.
88YJ, 350TBI, 700R4, Atlas 4.3, HP60, 14B (At a mall near you)
Tri-State (NJ-NY-PA) 4x4 Wheeling Group
xeon is offline
post #4 of 14 Old 08-28-2005, 03:55 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
addinbg a compressor won't hurt your engine output any since the clutch freewheels until you engage it. for the bracket i think you'll have to make one, i know kilby doesn't have one for my 2.5, but i have v-belts so yours could be different. turning the rear bumper into a tank has been done many times, and several manufacturers actually include that as a selling point.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #5 of 14 Old 08-28-2005, 04:17 PM Thread Starter
fastone110
fastone110's Avatar
i just went and looked.. its a v belt.. sentinal.. i take it u have a a/c compressor as OBA... if so could u post some pictures and info.. where does the a/c compressor on a stock jeep go.. or do i have to stick it in there...
post #6 of 14 Old 08-28-2005, 06:33 PM
sentinal02
sentinal02's Avatar
my york is sitting on the bench waiting for me to get around to building the bracketry. finally found a double groove pulley that will work with my alternator so this will likely be my next mod. the stock compressor mounts on top of the alternator but if you're using a york you can pretty much put it anywhere you want since the brackets are custom anyway. i'm thinking i'll mount mine to the pass side of the alternator but that might change once i start taking measurements.
post #7 of 14 Old 08-28-2005, 06:53 PM Thread Starter
fastone110
fastone110's Avatar
im going to the junk yard maybe tomorrow to scope one out..
post #8 of 14 Old 08-28-2005, 07:14 PM
sentinal02
sentinal02's Avatar
good luck. a lot of those things are in some tight spots to get two. took me 4 hours to pull minetry and make sure your clutch works before buying it. a new one will run you $100+ which kind of defeats the purpose of getting a JY comp.
post #9 of 14 Old 08-28-2005, 07:22 PM
TellyDSP
Poland and PPV!!!!
I'm going to try the sanden 709, which I picked up for $20 and will bolt right in. Although, after this weekend, I think I'm going to grab a CO2 setup for a main airing system.
BTW, Nick, you dont happen to have those couple shots from Trail 25, do you?
Edit: NM, just saw them in the JF Run thread.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #10 of 14 Old 08-28-2005, 07:26 PM Thread Starter
fastone110
fastone110's Avatar
u can remove the clutch cant u?
post #11 of 14 Old 08-28-2005, 08:32 PM
sentinal02
sentinal02's Avatar
yeah, the clutch comes off easy enough, but a new one is pretty expensive. being you've got the v-belts already you won't need to change the clutch as long as it works where as someone whole uses a serpentine belt would. unless they used a combo pulley of course. lots of different options here.
post #12 of 14 Old 08-28-2005, 09:27 PM
Steveyos
Steveyos's Avatar
I use the Sanden 709 compressor mounted in the stock location sice I do not have air. It will inflate a 35" tire as fast as CO2. I have taks mounted under the Jeep left of the transfer case. Also provides ARB Air.
Steveyos 92 Wrangler, 4.0L, 4" lift, 2" BL 33's 4.56 gears, lockers, SYE and more.
Steveyos is offline
post #13 of 14 Old 08-28-2005, 09:49 PM
TellyDSP
Poland and PPV!!!!
Any images or details of your setup. It's next on the list at some point. The compressor's sitting in my "to-do" pile right now. I may be picking up a CO2 also, but I'd like to have this as a backup/misc system.
Any info is appreciated. Thanks...
-Craig-
95 Rio Grande
07 Ram 1500
TellyDSP is offline
post #14 of 14 Old 08-28-2005, 10:24 PM
Steveyos
Steveyos's Avatar
Here you go.
Sangen Compressor in Stock Location
Inlet and Pump Oiler
Air Inlet
Air cleaner, Pop-off valve and switch
Air outlet
ARB Regulator in cab
ARB Locker Switch Location
Air Tanks drivers side of drive shaft.
Hope this helps, my total cost about 100 dollars but I got free tanks.
Steveyos is offline
On Board Air System Tcormier106 TJ Wrangler Technical Forum 7 09-09-2009 06:33 PM
Is it wise to do a tankless on board air system? jonlb YJ Wrangler Technical Forum 4 03-15-2009 08:28 AM
On-board Air deflation/inflation system? USMC2014 YJ Wrangler Technical Forum 19 03-03-2009 09:29 PM
need write up on york on board air system Wrangler11 TJ Wrangler Technical Forum 3 11-11-2007 10:58 AM
On board air system surfcaster JK Wrangler Technical Forum 40 12-15-2006 06:17 AM
