On board air - Page 2 - JeepForum.com
post #16 of 23 Old 01-31-2013, 11:59 AM
89YJBuilder
I have the Viair set up with twin 325cfm compressors and 2gal tank. I mounted it on the top of the wheel well. It is electric and draws some pretty good amps so you may want to make sure you have a good battery and alternator. I love it. the only thing I would do differently it to get the bigger compressors. Having said that I have never had a problem with what I got. As well living on a ranch it has proven to be invaluable.
The reviews section probably has reviews on OBAs.
Keep your boogger hook off the bang button!
When all else fails... ham radio is there!
KG6YSF
89YJBuilder is offline
post #17 of 23 Old 02-02-2013, 02:31 PM Thread Starter
fisyac
After many thoughts I want to convert a ac compressor but currently with limited funds I was wondering if any body used scuba tanks to re air or as there on board air I have several and I think they hold 3k psi?
fisyac is offline
post #18 of 23 Old 02-02-2013, 05:32 PM
debord97
debord97 is offline
post #19 of 23 Old 02-02-2013, 07:22 PM
czjeeper
I'm going to say that a York setup is "best" if you can make it work.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #20 of 23 Old 10-27-2013, 05:48 PM
W_A_Watson_II
I'm a little closer to having my On-Board-Air done. I've mounted the 1 gallon tank under the tub. I also fabricated a bracket to hold the pressure switch, T's, and fittings under the hood. To keep the under hood quick connect port clean, I used a fitting with a pressure gauge, this also allows me to know what the pressure is in the system. I also installed the ARB quick connect fitting on the rear of the Jeep behind the license plate. This should keep is a little cleaner, and not in a potential high damage area. Now to get the hoses from the compressor fabricated, and install the arming switch. The only bad decision I think I've made, is the arming of the system, will be by a switch that grounds the pressure switch circuit. If I'm not careful, I could leave the compressor on when the engine is off, running down the battery.
Will Watson
1993 Jeep YJ 4.6L Stroker (jeep.wawii.com)
1946 & 49 Dodge Power Wagon, 1953 Dodge M37
W_A_Watson_II is offline
post #21 of 23 Old 10-27-2013, 06:37 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Looks great thus far
Luck Favours The Prepared
Anticanman is offline
post #22 of 23 Old 10-27-2013, 07:22 PM
TrentYJ
Originally Posted by fisyac View Post
Does anyone have one and is one better than another?
I think the two important properties to look for on a compressor are the flow rate and duty cycle. Viair makes some pretty good units with relatively easy install.
"Arguing over the internet is like running in the Special Olympics...Even if you win, you're still retarded."
-François-Marie Arouet
TrentYJ is offline
post #23 of 23 Old 10-27-2013, 09:12 PM
89yjparrothead
I did the Saden A/C compressor mod and love it. The only thing I changed in my set-up was where I mounted the air/oil filter. I had first put it in the engine bay and what was happening was the plastic bowl would crack from the heat. I moved it to inside the passenger compartment next to my tank and have not had an issue with it since. That's my 2 cents if you decide to go this route. Good luck!
Everything in moderation, including moderation.
89yjparrothead is offline
